Question about Kenmore 22422 Top Load Washer
I need to know about the rubber attachment for the middle hookup?
I am hooking up my Kenmore washer, I need to know what is the rubber attachment that is needed for the middle hose? And also after hooking it up what are Zipties?
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What rubber attachment are you referring to? What is the model number of the unit?
Posted on Nov 28, 2012
jsrock516
  • 5911 Answers
SOURCE: Kenmore - 43142 front load - leaking
Which hose are we talking about? If you're talking about the small rubber hose at the top center of the door seal, HOW is it leaking? Is there a hole in the hose? Is the door seal itself damaged? Let me know a little more so I can give you the proper advice.
Posted on Jul 07, 2007
SOURCE: Kenmore 22062 top load washer
I have the same problem I posted on Bob Villa fix it website If I get an answer I will post it for you. Let me know if you found a fix.
Mllong9163
Posted on Aug 17, 2008
jsrock516
  • 5911 Answers
SOURCE: chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Sep 02, 2008
jsrock516
  • 5911 Answers
SOURCE: rubber boot and spring need put back in
Follow these steps:
1. Install the door bellow (rubber boot) back over the frame of the door opening ensuring you fit it snugly all the way around the door frame opening.
2. Insert the wire hoop in the rubber groove of the bellow where it fits around the outside perimeter of the door frame. Begin at the top of the door with the wire spring pointing towards the bottom.
3. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place.
It may be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 19, 2009
blueextc3221
  • 15935 Answers
SOURCE: whirlpool imperial dryer/kenmore 70 series heavy duty washer
This is a pilot-less ignition. You should wait at LEAST 48 hours for the water to evaporate as much as possible.
Longer if possible.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Kenmore washer 22422100 Top Load Washer
Could you please describe the problem you are having a little better?
Nov 28, 2012 | Kenmore 22422 Top Load Washer
L1719p flatron what do i need to hook up tocomputer
You have the standard data cable that attaches to the back of the computer (it's built in to the monitor), then you have your power cord. It is removable.
Apr 30, 2012 | LG Computers & Internet
Kenmore washer (110.92389200) drains, but will not agitate or spin; also, cannot turn the basket by hand. Where is the access for service?
check the motor coupling,take out the two screws that hold down the top console,flip up the console,unplug the lid switch harness in the middle or a little to the right from the middle and with a screw driver pop the two metal clips,tilt the frame to you and remove the whole frame of the washer.with a screw driver pop the two clips holding the pump on and slide the pump forward off the motor.take out the two screws and pop the motor clips and pull the motor forward,you'll see the motor coupling,there should be three arms coming off the coupling and three arms on the other part of coupling and a piece of rubber that they slide into,if it's cracked or worn in the middle replace the coupling and cut down on the size of the loads you put into washer.when putting the motor back on look at the four corners of the motor,if any of the rubber spacers are missing look where the motor goes and take the rubber spacers off the frame and stick them in the four corners of the motor and then line the motor up and install it,it's to hard to get the motor back if you don't do this.good luck and let me know what you find,if you need any more help let me know
Jul 31, 2010 | Kenmore Washing Machines
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Washer has one hose how do i hookup to 2 spigots
Those machines only have 1 cold water inlet.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2009 | Kenmore Washing Machines
Front Rubber Washer
Here ya go. Follow the steps outlined in this link:
If you have questions along the way, please let me know. If you need to know where to purchase a new door seal, also let me know. Post back with your model number for clarification. I hope this helps you.
May 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Chenging the rubber gasket attached to kenmore H2e front load washer
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Hooking up a used washer
there should not be anything else. can you send a picture, because someone may have rigged it somehow.a077143.jpg
Jul 06, 2008 | Kenmore 12502 Top Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
