Question about Keurig Platinum B70 Coffee Maker
Keurig stuck in brewing cycle - Keurig Platinum B70 Coffee Maker
3 Suggested Answers
SOURCE: keurig b70 coffee maker stops brewing mid cycle
coffee maker stops brewing half way through brewing.
Posted on Nov 23, 2010
heatman101
  • 43501 Answers
SOURCE: I press the brew button
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
Keurig B77 Platinum Series stuck on Brew setting.
I heard that these Keurig coffee makers can't be totally cleaned inside the rubber hose develop a mold that's nasty .
May 05, 2017 | Keurig Coffee Makers & Espresso Machines
How do I descale my Keurig 20 coffee machine
Start the brew cycle without inserting a K-cup. Repeat until reservoir is empty, discarding the mug contents after each brewing cycle. This process will help remove lime and scale buildup. Keurig recommends descaling your brewer at least every 3-6 months depending on your water source.26 Apr 2015
How to Clean a Keurig Coffee Machine - Cleaning Lessons from The ...
www.thekitchn.com/how-to-clean-a-keurig-cooking-lessons-from-the-kitchn-218103 https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=How+do+I+descale+my+Keurig+20+coffee+machine
Dec 22, 2016 | Keurig Coffee Makers & Espresso Machines
Stuck in brew cycle
Unplug it and let it sit for 5 minutes, if this does not work, your Switch may be stuck and needs to be cleaned, Never work on Live Circuits
Apr 11, 2013 | Keurig B60 Coffee Maker
My keurig platinum will pump the water, say ready to brew, but when I press brew it will not do anything. It is like glued on the brewing cycle.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Apr 16, 2011 | Microwave Ovens
I press the brew button and the Keurig states that it's brewing, but will not brew. It seems to be stuck in brew mode without brewing anything.
heatman101
Apr 11, 2011 | Keurig B60 Coffee Maker
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
It is stuck on large and does not brew
My keurig did the exact same thing. Stuck on large and wasn't pulling water into coffee maker so it would only dispense a small amt of coffee. I turned it off for about 10 mins. Emptied the reservoir and filled it half way with white vinegar. Ran several cups through and after 2nd brew it ran faster and after the 3rd run with vinegar all the size cup lights came back on. It is working great now. Just empty reservoir with remaining vinegar and rinse. Run a couple cycles of plain water through the coffee maker to rinse out vinegar. I hope this works for you.
Dec 27, 2009 | Keurig B60 Coffee Maker
Descaling light on
Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
1) turn off the "Auto Off "feature
2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
4. Press the large mug Button
- let Keurig coffee maker fill mug with vinegar & empty in sink.
5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
6. Rinse the water reservoir thoroughly and fill with fresh water.
7. FINAL STEP RINSE CYCLE
a) place a ceramic cup on the drip tray
b) run regular brew cycles WITHOUT using a K-cup.
c) pour rinse water into sink each time.
d) repeat brew process until water reservoir is empty.
d) perform additional rinse cycles if you notice any residual vinegar taste.
e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
Otherwise - you're good to go!
Apr 16, 2008 | Keurig Elite B40 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
79 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
