Question about SAMTRON 55V 15" CRT Monitor
Power not wrokign properly
I have a monitor using a dp704c ic and a HOT c5931.i shows power but after 2 seconds it goes on and off.and i am hearing a tik-tak like sound on its relay section with an interval of 2 seconds each sound.then after a few tik-tak like sounds i shows oscilation on its crt.but only for 1 second then same thing happens again...please help to solve this problem..
thanks postal111
  • 55 Answers
Check secondry side of sm txr for shorting
Posted on Apr 30, 2009
2 Suggested Answers
  • 137 Answers
SOURCE: power switch is on, monitor
CHANGE ALL THE CONDENSERS IN THE MAIN SUPPLY UNIT, THA WILL FIX THE PROBLEM.
Posted on Mar 01, 2011
Equivalent of transistor c5929
2SC5929 - Si, NPN, diffused CRT Horizontal Deflection Output Transistor.
Producent - Matsushita/Panasonic
(Absolute Maximum Ratings)
IB=5,5A
Ic=12A
Icpeak=22A
VCB0=1550V
VCE0=600V
Ptot=50W
similiar tx; C5931, C5129, C5587, C5909
Aug 05, 2010 | Computers & Internet
Xerox XG-19D LCD monitor goes black in 5 seconds
You may also have to check the IC/Transistors Inverter transfomer drivers, also should Ohm out the resistance of the transformers.
Mar 18, 2010 | Xerox XG-91D 19" LCD Monitor
Hp f2105 only stays of for 2 seconds
Hi there mate i have a hp f2105 with the benq power supply in it which as gone faulty could u look at your power supply and tell me the numbers on the power ic which is ic651 thanks.
Jan 13, 2009 | HP f2105 21" LCD Monitor
Liquid Video monitor goes black after 30 seconds
Capacitors on the power board inside the lcd monitor have blown they can be replaced with new ones and the monitor should return to normal operation.
service center or if you feel capable you can do it your self with a soldering iron and the correct caps that have blown you need voltage and micro faradays usually 25 v at 470 mfd (u)however monitors use different kinds and voltages can be different it will be marked on the side of the damaged capacitors.
l8r
Nov 11, 2008 | Computers & Internet
MOBIN_KHORSHIDEE
Samsung Monitor Model: Syncmaster 753S (ANNN17LS7L/EDC Chassis)
No power
I discovered IC601 (DP704C) had exploded, Equivalent for this IC is 6S0765RC
(Anonymous)
http://www.e-repair.co.uk/tipsmon.htm
Sep 04, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
SMPS IC for Samsung 753S Monitor
Can you help me about SMPS IC DP704c on jitendereco@gmail.com
Aug 18, 2006 | SAMTRON 55V 15" CRT Monitor
56 V - faint horizontal lines across the display
u can search problem in vertical section may be sum IC component was dry resold them .
Aug 02, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
173 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
