Question about Kobo 6" eReader Touch Edition
Screen reads Restoring your device to factory default
It is frozen on this screen, needs to be pluged into the computer to have a green light on or it will turn off.
I don't know my password to Ipad need to hard reset
Can only be done via a computer that has iTunes on it. Log in with Apple ID, back up the device and then Reset.
If you know the password it can be reset via Settings.
Mar 23, 2017 | Tablets & eReaders
How do I do a factory recovery on my mini ipad
iTunes enables you to restore iPad mini to factory settings. Before you start restoring iPad to factory settings, please note that you need to install the latest version of iTunes on your Windows computer or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPad with iTunes as follows.
1. Plug iPad into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPad at the upper right corner of iTunes, and then the information of your iPad will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPad before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPad. Then iTunes will start restoring your tablet to factory settings.
4. Click Restore again to confirm. Then iTunes erases your iPad and installs the latest iOS software. After you restore your device to factory settings, it will restart. Now you can set it up as new.
http://www.leawo.org/tutorial/how-to-restore-iphone-6-plus-to-factory-settings.html
Nov 06, 2016 | Apple iPad Mini
My SM-T550 is completely frozen.
Soft Reset
If the device is frozen or unresponsive, try pressing and holding the “Power” button for about 20 seconds. This should force the Galaxy Tab 10.1 to restart normally.
Hard Reset
A hard reset will set the device back to factory default settings and erase all data on the device. This is normally done when troubleshooting methods prove to be fruitless.
Option 1
1.With the device powered off, press and hold the “Home” and “Volume Up” buttons while powering on the device using the “Power” button.
2.The Recovery Screen will appear. Use the volume buttons to toggle the highlighted selection to “wipe data/factory reset“. Press “Power” to select it.
3.Highlight “Yes — delete all user data“, then select “Power” to choose the selection.
4.Once the reset completes, you will be prompted to “reboot system now”. Choose this selection to restart the device.
The hard reset is complete.
Galaxy Tab How to Hard and Soft Reset
Jan 02, 2016 | Samsung Galaxy Tab Tablet PC
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
My kindle will not turn off
Did you try
Instructions
  1. Frozen Screen or Unresponsive Kindle
    • 1 Unplug the Kindle.
    • 2 Move the power button to the right and release. You should see a green LED light for two seconds.
    • 3 Move the power button to the right and hold for five seconds. The green light should blink three times and then the screen will go blank. Release the power button after it does.
    • 4 Turn the device back on by sliding the power button to the right and releasing it.
    Perform a Hard Reset
    • 5 Perform a hard reset if the previous steps are unsuccessful or if the Kindle screen is showing lines.
    • 6 Slide the power button to the right.
    • 7 Hold for 15 seconds.
    • 8 Recharge the battery if the device continues to be unresponsive.
    • 9 Restart the Kindle after charging.
Read more : http://www.ehow.com/how_7655306_reset-kindle-3g.html
Jul 29, 2014 | Amazon Kindle 3G
Amazon kindle reader reset
To perform a hard reset of the Kindle just press and hold the power on button for 20 seconds as described in the Kindle Support web site for dealing with Frozen devices.
If you want to reset your Kindle back to Factory defaults then you would need to press the Menu button, then go into Settings and you will find an option there to Reset to Factory Defaults.
Dec 30, 2011 | Amazon Kindle Wireless Reading Device
My amazon kindle screen is frozen on the right hand upper corner. The rest of the screen is still fine and works but that corner is frozen.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Jan 02, 2011 | Amazon Kindle 2
My kindle is frozen. I cannot reach my home page. I am stuck between the last thing I was reading and the kindle store and I cannot go anywhere else. It has been like this for 3 days.
Dec 15, 2010 | Amazon Kindle Wireless Reading Device
Kobo 6" eReader Touch Edition Logo
156 people viewed this question
Top Kobo Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
Andrew Taylor
Andrew Taylor
Are you a Kobo Tablet and eReader Expert? Answer questions, earn points and help others
