Question about Kenmore 22422 Top Load Washer
Kenmore washer 22422100 Top Load Washer
I am hooking it up. What does the rubber hose attachment look like?
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 28, 2012
jsrock516
  • 5911 Answers
SOURCE: chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Sep 02, 2008
appldoctom
  • 311 Answers
SOURCE: top load kenmore 110
it's your pump! thats the most common leak on kenmore top loaders.it located low ,front and .you can tip washer back towards wall and inspect.the pump is white and has two hoses to it.
Posted on Jan 24, 2009
  • 240 Answers
SOURCE: kenmore top load washer 92573210
4 springs on bottom of washer 3 from tub to top of base hidden, 1 from rear tub to bottom of base straight down, hole in inner lip of base, to counter weight of motor.
Posted on Apr 26, 2009
honeymokey
  • 3113 Answers
SOURCE: Describe your Kenmore 24032 \ 24036 Top Load
Water pump is my first guess. Did you check the hoses that hook to it? The pump is in the front of unit. Give full model number to further assist you.
Posted on Jun 16, 2009
blueextc3221
  • 15935 Answers
SOURCE: Removing the top of a Kenmore Elite Oasis Washer to replace hose
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Washer is leaking by the hoses
If your washer is leaking from the connection where the hose and the hose end join, replace the hose. If it's leaking from where the hose attaches to the washer, check and see if there is a rubber washer inside the hose end, there should be, try replaceing the rubber washer inside the hose end,
Aug 01, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
I need to know about the rubber attachment for the middle hookup?
What rubber attachment are you referring to? What is the model number of the unit?
Nov 28, 2012 | Kenmore 22422 Top Load Washer
I need a washing machine manual for a Kenmore top loader, model number 22422100
Please check your model number. Kenmore washers have a 3 digit prefix followed by another 8 digits. If your full model number is 110.22422100, then Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/12008/KENMORE-Residential-Washers-L0407343?brand_name_search=110.22422100 . This is a generic manual for all Kenmore one-speed automatic washers. A copy of the descriptions of the washer settings is available here: http://www.managemylife.com/mmh/owner_manuals/15224/KENMORE-Residential-Washers-L0305156?brand_name_search=110.22422100 .
I hope this helps. If your washer has a different prefix, please add a comment with the prefix. I'll try to find manual for the correct model.
Jan 22, 2012 | Kenmore Washing Machines
Sink attachment for washer
repairclinic.com, appliance411.com, or ebay.
Sep 15, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Jun 15, 2009 | Kenmore 24032\24036 Top Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking washer
Replace the valve, or if new, have them do it. You are sure it is the valve and not where the hot warter hose attaches? Confirm by hooking up hot water under preasure to see if that seals itself.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Water hose leaks at the washer connection
Did you change the rubber washers in the hose? or did you use the old ones there should be a rubber washer inside the front of the hose.
Jan 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 22062 top load washer
I have the same problem I posted on Bob Villa fix it website If I get an answer I will post it for you. Let me know if you found a fix.
Mllong9163
Jul 19, 2008 | Kenmore 22062 Top Load Washer
Kenmore HE2plus
the f20 seris usually means a water problem ..ckd both faucets are fully on and connected correctly ckd screens in connection at end where hooks to washer.screens are inside connection be sure they are clean has also been a problem with water level switch remove top to locate it on right side with small hose attached
Jul 14, 2008 | Kenmore 46462 Front Load Washer
Kenmore 22422 Top Load Washer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
