Question about Whirlpool GS460 Gas Kitchen Range
Error code foeo
Oven won't light. burners work fine
fridgetech
  • 473 Answers
SOURCE: oven will not light/no trbl code/top burners work fine
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 03, 2007
  • 512 Answers
SOURCE: Burners and oven wont work
Sounds like the thermal fuse is burned out. If you look on back of stove or pull out drawer you should find wiring diagram. Look for thermal fuse. With unit unpluged test with a tester. If found to be bad replace. This is probably you problem.
Posted on Jun 17, 2009
localwonder
  • 6784 Answers
SOURCE: Oven wont work,stove (burners work fine
HI. this is a self clean latch malfunction code.
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Posted on Sep 22, 2009
  • 2006 Answers
SOURCE: WFG381LVS-broiler and over won't light
Gas valve PART NUMBER: 9761959
$108.58
In stock
Qty: pd_0022_664_9761959?op_sharpen=1&qlt=100
Posted on Jul 05, 2011
jumptrout51
  • 3361 Answers
SOURCE: Is there any kind of pilot light that I need to
There may be a gas shutoff on the range gas supply. If so,turn it on.
If it is already on,turn on a surface burner and use a match ti light it.
It will take several minutes for the air to purge from a system once gas supply has been restored.
Posted on Aug 03, 2011
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Oven pilot light won't light. Stove burners work fine.
if you have a pilot flame oven replace your thermocouple
if you have a newer oven you will have an ignitor
please advise me on whitch type of oven you have
Feb 05, 2013 | General Electric ge JGBS04BPW wb1k5 Oven...
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Burners work fine, pilot light in oven is on, but oven won't ignite
Make sure the thermocoupler is being heated by the pilot light flame. It could also be gunked up but you can clean it with a scouring pad, or it might need to be replaced. The thermocoupler is the most likely cause because if it isn't heated then the gas valve will not open up and no gas will flow to the burner. Since your pilot light is on then you do have gas to the valve.
Aug 28, 2011 | Ovens
The oven works just fine, but my burners won't light unless I use a lighter. I think it might be the ignitor may have went. Is there any advise you can offer
When you turn the burners on do you here them sparking ? if not the spark module has gone out it's the most common failure when burners dont light
Hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 31, 2011 | Maytag MGR5752BDW / MGR5752BDQ /...
I have a Maytag gas stove model MGR5730BDW. The oven won't light. The broiler works just fine. The bottom ingiter glows orange and gets hot but the burner won't light.
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Whirlpool GS460 Gas Kitchen Range Logo
20 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
