Question about Singer Merritt 8734
The bobbin stop spinning, the needle broke every time I try to sew, it seem as though the needle hits the metal part below the bobbin bucket. Please help
5 Suggested Answers
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 240 Answers
SOURCE: breaks needle
Yes they can indeed go out of time and breaking needles is the most likely cause. To solve timing problems you will need a sewing machine engineer though. The part which needs adjusting would be the area above the needle-the needlebar but it is a fiddly affair only to be attembed by someone who can repair sewing machines. It is also a fairly expensive repair as it is very time consuming. However-don't assume it is that. Firstly make sure the new needle is in correctly-the most common cause of problems is needles in wrong direction! If bobbin opens at front then the flat part of the needle faces the back. If bobbin area opens at side then the flat side of needle faces the body of the machine to the right. Check needleplate for damage so that new needle does not catch. File it smooth if you need to! Check you are using a good quality thread as cheap thread causes no end of problems. Guuterman is the best I found.
Posted on Jun 11, 2009
  • 55 Answers
SOURCE: Needle hits the bobbin spindle and makes a "clonking" noise
it sounds like the timing is out. are you confident the needle is fully inserted into the needle holder? if so take it back to the shop or look here for instructions on repair for stylist machines. http://www.tandtrepair.com/StylistLine.html
goodluck,
scott
Posted on Jul 28, 2009
  • 1788 Answers
SOURCE: I have an old but
Time for a tune up and the timing to be reset. People tend forget that machines do need to be serviced once in a while, it will be well worth it. Just remember it is a machine, just like your car.
Posted on Sep 26, 2010
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
I was sewing just fine then the needle broke ... I replaced it only to find that the next needle broke too. It seems that the needle just hits the rotating metal below the bobbin each time it goes...
First make sure there are not bits of needle left in the needle holder, or down in the bobbin area. Take out the bobbin, take the bobbin carrier out. Take off the foot. You need to see.
Look carefully at the shuttle while rotating the hand wheel in the direction of sewing until the needle is at it's lowest position. Where is the shuttle's Point? (past the needle? or way behind the needle?)
I think your machine is out of time. You may need to take it in for timing.
Nov 10, 2012 | Sewing Machines
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
I have a Thompson PW 201 machine . It will not sew through more than one piece of material. I have been using this machine to sew through four pieces of vinyl and never had any problems. Now if iI try...
it sounds like to me that the timing is off, check to see how close the needle is to hitting the bobbin when it comes down through the table. that metalic clunk is probably the needle hitting the bobbin holder, OR the bobbin.. check for a bent needle also..
Oct 17, 2010 | Olde Thompson PWZ500
I used the embroidery bobbin sewing and now it's not functioning
I do not believe the bobbin thread is the reason for the problem.
Refer to your manual for maintenance, especially cleaning the bobbin area.
When you replace the bobbin case be sure the needle is in it's highest position and this will also set the shuttle in position to properly accept the case.
If the problem continues, then machine will need to go into the shop. If the timing needs to be adjusted, this is best done by a Bernina tech.
Apr 28, 2010 | Sewing Machines
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Bobbin not turning, possible motor/gear issue?
You have a broken vertical shaft gear. It's very easy to replace if you are mechanically inclined. The gear can be purchased for between $8-14 from a sewing repair store and I can walk you through the process.
Jul 19, 2009 | Sewing Machines
Singer Merritt 8734 Logo
19 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
