Question about Pool & Spa
Pump leaking at shaft - Pool & Spa
    Scholar:
  • 111 Answers
That would mean your shaft seals aren't function as they should.
You would need to determine the make and model of your pump to figure out which seal you need.
Try this article - http://spapartsshop.blogspot.com/2012/09/pump-shaft-seals.html
That should help...
Posted on Nov 28, 2012
I have a 953 track loader the throttle shaft on the injector pump is leaking oil do i have to replace the injector pump
Bad O-ring on shaft. You may be able to do it yourself, but definitely not a complete pump unless you have a cracked pump or serious injection performance problems thus bad engine performance. Double check pump shaft. area. may need to remove a cover to the drive. Usually, there is a diesel return line I suppose there is a slim chance that is pinched or plugged somehow. Check to make sure it's clear. Possible that supply line to Injunction pump is leaking at the connection, also usually a bad O-ring. Find a leak by
wraping a paper towel in places to discover the leak. Or there is
a black light kit with dye to discover leaks.
Dec 22, 2014 | Cars & Trucks
Onga 4352 Spa Pump is leaking from the opening in the bottom of the pump. I have opened it & siliconed the Oring seal but it continues to leak. Any suggestions?
I had a new pump brought to me once that continued to leak after replacing the shaft seal three times. Careful examination revealed a sand casting fault in the pump body. The water was leaking through the body of the pump. Have you replaced the shaft seal?
Nov 04, 2014 | Plumbing
Leaking water pump
If coolant is leaking out of the water pump shaft, it needs to be replaced. Cooling system sealer can't stop this type of leak.----------------------------------------------------------------------------------
VAS 5054A
Dec 17, 2012 | Cars & Trucks
Leak on pump
Most common leaks on these pumps - Shaft Seal.
Replace the pump Shaft Seal.
It looks like this:
Aug 20, 2012 | Hayward Super Pump 2hp, Sp2615x20
Moter leaks when filtering
Is it leaking at the motor shaft or where the filter gasket and pump housing bolt together? If between the two housings,then it may just be a matter of tightening the screws that hold them together. If it is leaking around the shaft, you will need to replace the mechanical shaft seal.
To replace the seal you will need to remove the housings and then unscrew the impeller from the shaft. There is a slotted end on the other end of the motor shaft for screwdriver. This will hold the shart still while you unscrew the impeller. The shaft seal is a precesion part so be careful when replacing it.
Let us know if this helps, Robert
May 16, 2012 | Craftsman 1 - 1/2 Hp Pool Filter Pump
When an oil pump is supposedly "leaking" while a maintenance/replacement is being performed on the timing belt [at a 100K checkup], where would the leak be "leaking to"?
The pump is driven by the timing belt, so the oil pump shaft sticks out of the engine to access the belt. The leak would most likely be the oil pump shaft seal.
Sounds like you’re skeptical.
Jul 07, 2010 | 1999 Subaru Legacy
2001 dodge 2500 diesel oil leak in front of power
The power steering pump is piggie backed to the vacuum pump. The seal in the back of the vacuum pump has engin oil under presure behind it cousing a leak that gets worse over time. Cummins make a seal kit to fix this leak.
Dec 26, 2009 | 2001 Dodge Ram 3500 Truck
Lost alot of antifreeze leaking by pulley
water pump is leaking past the shafts seal as there is a drain hole for that very reason [to show you it leaking] or its gasket has failed or pump bolts nead tightening
check pump for play in the shaft! [wobble the pully]
is it moves replace the pump!
Jul 20, 2009 | 2003 Chevrolet Malibu
Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Jun 03, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pool & Spa Logo
23 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
