Question about Uniden Cordless Phone
Need help registering the GE additional cordless model 27911.
  • 3 more comments
  • Alex Tan Jan 10, 2009
    Didnt help at all. That was all I did. You just gave me the instruction manual all over again. Followed that a couple times and still wont register. Ive been reading the forums and it seems that manual doesnt do any good at all.
  • Anonymous Jan 12, 2009
    why i have registered my phone evry day
  • Anonymous Feb 15, 2009
    same problem here-won't register
  • Anonymous Mar 13, 2009
    Same issue, same handset
  • Anonymous May 15, 2009
    I have the same problem. I have the 27909EE1 base station and I can't get my newly purchased handset (model 27911EE1) to register with the base. It simply times out and emits an error tone. I am able to un-register and re-register the handset that came with the base, which is identical to the newly purchased model. I've tried registering both at once, unregistering the base handset and registering the new 27911EE1 handset but no luck.
    I think I've narrowed it down to a hardware problem which is just annoying. Any ideas?
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Posted on May 15, 2009
  • 15,935 Answers
Here is your owners manual.
http://www.home-electronics.net/ge/pc/IB/27911EE1_IB.pdf
Registration
A cordless handset will not operate until it is registered to the base. During the
registration process, keep the handset near the base. Up to 4 cordless handsets can
be registered to one base.
NOTE: If a handset is not registered; Not Register flashes on the
display and if the TALK button on the handset is pressed, it will
display Unavailable.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to
scroll to Registration.
3. Press menu button to confirm and you may program the following items: Register
and Remove handset.
Register
From the Registration Menu:
1. Press the cid/vol (3or4) button to scroll to the Register sub-menu.
2. Press menu button to enter the menu.
3. Press and hold the page button on base for 5 seconds.
4. The charge/in use indicator will flash slowly for 2 minutes which indicates the
base is in registration mode.
5. If the registration is successful, the handset screen displays Successful and emits
a confirmation tone for 3 seconds.
6. If the registration is failed (i.e. timeout), the handset screen displays “No base” and
Posted on Jan 10, 2009
How can I register my GE 27911 handset?
I also had this problem and then I found a solution from another site.
Just open the handset and remove the battery for about 1 minute.
Reinstall the battery and go through the register procedure again - it will register almost immediately. just keep the handset near the base.
Jul 18, 2009 | Uniden Cordless Phone
I have a GE cordless handset Model 27911 that I cannot get to register to the main base unit which is a GE Model 27909. I have tried followed the instructions and still the handsets says "Not register."...
trun off phone and remove battery
remove power from the base unit
and leave them unpluged for 5 mins or more
then turn both units on
and replce onto base unit . Good luck
May 04, 2009 | Uniden Cordless Phone
Need help programming autodial feature on my ge-27923-ge cordless phone
how do you change GE Model 27923 2.4 GHz cordless phone from pulse dial to touch phone dial? I lost my instruction manual Thanks
Apr 15, 2009 | Lands Phones
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I took the post that mentioned removing the battery, waiting a few minutes and then reinserting it.  It worked.  Thanks to that person.
Apr 14, 2009 | Uniden Cordless Phone
Can't get handset to register
After each registration of a handset, you need to hold the page button on the base for 5+ seconds. If you then get an error tone, you'll likely have to return the phone due to a hardware problem. What did you do?
Apr 05, 2009 | Uniden Cordless Phone
Change time
The time on mine automatically set itself when a call came in from a phone allowing you to see caller id.
Feb 15, 2009 | GE 28111EE2 Cordless Phone
I have a GE 25922 5.6GHz cordless phone. It has 3 receiver. 1 of the receiver all ways says unavailble and it does not ring or can't call out. Can you help me with phone? Thank you, Sai.
UNAVAILABLE Indicates the handset is out of range. Or an additional handset is in use. Or there has been a base power failure, in which case you must place all handsets on the main base cradle for 20 seconds to re-register.
Jan 07, 2009 | GE 25922 Cordless Phone
I CAN'T REGISTER HANDSET FOR GE MODEL 27911 DECT 6.0
Did you follow step by step instructions leading up to Registration; i.e HS Setup and BS Setup??
Dec 28, 2008 | Jwin G.E. Thompson: GE-29257GE1 Corded...
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Jan 20, 2008 | GE 28111EE2 Cordless Phone
Uniden Cordless Phone Logo
894 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
