Question about KitchenAid KHWS01PMT Front Load Washer
Soap will stay in reservoir. Using liquid He - KitchenAid KHWS01PMT Front Load Washer
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
You may need to remove the top to access the dispenser lines to clear them of any buildup or blockages.
Posted on Nov 28, 2012
How to Clear out dish soap from the jet dry resevoir?
Use a shop vac and suck it all out. Then, spray some Pam-type cooking spray grease into the jet dry reservoir and then, A) start a normal wash cycle and stop it a few minutes after it starts the spray action. Then, open the door and look for suds. B) If you see suds, spray them with Pam spray to knock them down and then C) cancel the wash to drain it out. Repeat ABC until all the suds are gone.
Then, whatever you do, DON'T put dish soap in the jet dry reservoir again!
Good luck
Oct 21, 2014 | KitchenAid Dishwashers
Isn't using the soap appropriTely
I would either switch soap and us a liquid soap or fill the reservoir with less soap. A dishwasher does not need to use a lot of soap since it uses very hot water.
Feb 01, 2018 | Frigidaire FPHD2491K Builtin Dishwasher
Can you use granular soap and where to apply it? we have a frigidaire washer with a drawer to put liquid soap in.
On our washer there is a little slider in that drawer that allows the opening into the washer to open wider for solid laundry soap. Maybe that's the case in yours. If not then you might be confined to using HE liquid soap.
Mar 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Extra suds due to liquid soap in the machine overflowing. How do I drain it?
This is strange. Are you using an electric dishwasher liquid soap, OR are you using a dish soap that you manually use to wash dishes?
REGULAR dish soap liquid that is not specifically made for dishwashers creates a foamy suds with lots of bubbles that will in fact bubble out of your dishwasher. on the other hand. Electric Dishwasher detergent will NOT create foamy suds with lots of bubbles.
Switch your soap. The next cycle any residue suds or soap will be gone as long as you use the proper liquid detergent. I would also recommend using a rinse agent which further helps break down and rinse off residue.
Mar 18, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Wont drain
Should not be any soap at all. If the soap has small shiny bubbles in it you have an oversuds problem which will cause the pump to cavitate during pump out. After setting for while the soap turns into water until the next wash. Easy fix is use 1/2 cup of liquid fabric softener and run thru complete cycle with heat dry off to dissipate all of the soap residue. Hope this helps.
Feb 02, 2010 | Dishwashers
13 year old daughter put liquid dishwashing soap in the rinse dispenser. Now all dishes come out covered in soap scum. How do I get liquid dishwashing soap out of the rinse dispenser?
Sorry but thats funny!!lol About the easiest way I know to tell you is take a turkey baster or marinade injector & draw as much as you can out of the reservoir,fill it with water & repeat until you get very little foam when putting water in it.Fill with rinse aid & the rest will just have to work its way through.Should be fine after a few wash cycles.
Jan 07, 2010 | Admiral 24 in. DWUA601 Built-in Dishwasher
Water in the bleach reservoir after each use
The dispenser door is caked with old soap and not closing all the way. (most likely)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore HE2 Plus Front Load Washer
Sears / Kenmore top-loading washer does not dispense bleach
Remove the tray and check the proper operation of the solenoid for the door.
May 31, 2009 | Kenmore 23822 Top Load Washer
Soap Not Mixing
Inside the soap holder there is a small spring and sometimes that comes under causing it not to open during the wash. If that is fine and you are using liquid soap try pulling a cople glasses of hot water on the latch and give it good clean because it soemtimes gets jammed up. Anymore questions give me a shout.
Jul 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
KitchenAid KHWS01PMT Front Load Washer Logo
14 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
