Question about Microsoft Xbox 360 Console
3F45-0000-0080-0300-8007-2751 when i turned my xbox on i had to do an update and it gave me this code and told me to test my xbox live connections there is nothing wrong with my internet but it keeps having problems with connecting to my xbox live numerous of times
    New Friend:
Have you made sure you DNS settings are set to automatic? Mine were manual and I had the exact same. I switched to automatic and gave it a try. Worked no problem!
Posted on Nov 28, 2012
    New Friend:
Reinicie o seu roteador.. =D.
BillyHoWCR
  • 116 Answers
SOURCE: when I go to download
Try going into your network connections and doing a test connection. It should log you out do the test succesfully and then attempt to redo the update. It should ask you to update again and just accept the update by pressing the A button.
Hopefully it should update your system without the error this time? Good luck.
Posted on Jul 21, 2011
tbeatles90
  • 6 Answers
SOURCE: xbox asking for update. wont install update! CANT PLAY HELP!!!
as i tell everyone with this problem with other games too go buy a new concolse if that helps i hope it does
Posted on Jan 16, 2009
SOURCE: Problems connecting to xbox live gold
how do i input code for gold membership
Posted on Mar 13, 2009
  • 39 Answers
SOURCE: the internet is connected to the xbox but the xbox live will not connect
Restart your modem or router, give it 30 minutes, and try again. If you still are not on live just check the tips they give you
Posted on May 30, 2009
  • 33 Answers
SOURCE: Similar problem restated: Xbox live won't work
Router isn't correctly configured
Posted on May 09, 2010
I'm losing my connection...
It sounds like you've refused an Xbox Live Update at some point.
You can go into your system options and see if there's an update available.
To check for an update on the Xbox 360 you basically force a new Xbox Live connection:
  1. Press the Guide button (center logo button), bringing up the pop-up menu
  2. Go to Settings
  3. Select System Settings
  4. Select Network Settings
  5. Select Wired Network or the name of your wireless network if you're on wifi
  6. Select Test Xbox Live Connection
  7. Select Yes if prompted to update. If you're not prompted and the test completes successfully, you have the most recent update.
If that doesn't work try this link http://www.gamefaqs.com/boards/927749-xbox-360/67807343
Jan 08, 2017 | The Video Game Consoles & Games
When I did the xbox live test from were it keeps kicking me off saying not enough banwidth while I was trying to play battlefield3 it said service alert and it gave me a bunch of codes 20A8-4840xbox360...
don't simultaneously use other device connected when you are on xbox live , then you ll have difficulty playing on xbox live .
Make sure you disconnect all other devices connected to internet before you connect you xbox to internet
if you have no devices connected to your internet then may be some one has hacked your wifi
change the wifi password , it ll fix the issue :)
Jan 23, 2013 | Microsoft Xbox 360 Console
I have xbox live but cant update it.
The new update for xbox 360's launch of Kinect is causing problems. I fixed mine by going into System Settings, Network settings, then running a test on xbox live. Initiating the test logs your profile out then runs a network test. The test completed with no problems and then asked me if I wanted to update again. Without logging back into my profile I clicked OK and the update ran without a hitch. I think the solution lies in the fact that my profile was logged out and from what I have seen, the only way to connect to xbox live without a profile being logged in is with a network test. Once you connect to xbox live it senses that you don't have the update and asks you again, this time without a profile logged in and you are able to do it.
Nov 01, 2010 | Microsoft Xbox 360 Console
Still my xbox live update test fails...
It is your modem, try switching out and see how that helps. Also sometimes the broadband won't work
Oct 21, 2008 | Netopia 3347W-KIT ADSL Wireless Gateway,...
We had new cable company installed and we had to use a router. We cannot get on xbox live
go onto the connection page on your xbox and then do find connection or anything related to testing connection. once you find it, whatever you named you router on your computer will show up there. once connected, do a connection test and look for any updates. update them and then turn of you xbox. turn it back on. REMEMBER...only games that say Xbox live on the top of the box will work. then start playing
Jul 07, 2008 | Video Game Consoles & Games
Netopia's Modem my also act as a Router protecting your system from internet traffic! You need to check your model to insure what you have. If it is a Router you will have to Contact Netopia in regards to configuring Pin Hole on the Router to open the gaming ports on the Router.
Coach "J"
Have a great 2008!
Jan 07, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Xbox live test fails and so does update
you need to open the port that the update is trying to go through. the easiest way is to turn your firewall off, but this opens up your security. another way is to forward the correct port through port forwarding on your router. findout which port xbox live uses and put in the information to the router
Jan 06, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Microsoft Xbox 360 Console Logo
1,920 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
