Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Where is the mitsu65511 power board located - Mitsubishi WD-62525 62" Rear Projection HDTV
  • George Sauer Dec 24, 2012
    No longer have the Mitsubishi T.V. Too many problems
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
As you look from the back board on far right is main power supply but there are also parts on the middle board that are part of the power supply.
Posted on Dec 22, 2012
Model L37. Why does it keep shutting off about 10 seconds after it's turned on?
The main power board is going bad. More specifically, the power amp chip is going bad. Note: Some Vizio TVs have the power amp chip located on the board where the power button is located. Many people change the main power board only to find it fixes nothing because the chip is not on that board.
Feb 08, 2016 | Vizio Televison & Video
Where are the fuses in my vizio vf550xvt
the main power supply fuse will be located on the power board. Just follow the power cord to the power board, the fuse will be close to the power connector. FYI, there are also fuses located on the main board, t-con, and inverter boards.
Dec 09, 2012 | Vizio Televison & Video
Fuse locations vizio e470vle
The fuse will be located on the power supply board. The power supply board is the one that the power cord plugs into. The fuse should be close to where the power cord plugs in at.
Dec 06, 2012 | Vizio E470VLE 47 Class Widescreen LCD HDTV
Where are the fuses located on a 37 inch flatscreen magnovox?
The fuse can be located on the power supply board. To locate the power supply board, trace the TV wire back into the TV. The area where the TV wire is soldered inside the TV is the power supply board. There is fuse on the board. So this means you have to disassemble the TV....
Regards.
Walesarumi
Sep 28, 2011 | Televison & Video
Pushed the power button but the tv does not turn on
Hi.Please check the fuse of your television located inside the TV.Try to remove the back cover of your TV and find the fuse location.Its located at the back right near the power supply.Check it if is busted and replace the same valiue of fuse.Unplug the TV before removing the cover to avoid electric shock.tanks
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Turn itself off as soon as you turn it on (37MF33ID/37)
in the lcd tv there are three main parts
1)the inverter board(pannel)
2)the main board .
3)the power supply board.
if there is no power at all them main board is faulty.if no front led light is coming ON there is no power .so the main board is faulty.on the main board there is a fuse located you have to replace that and check first if still no power main board needs to be checked and replaced
if there is sound but no picture and front led light is ON then its inverter board panel problem.if this is your case replace inverter panel.its located in the lower side of the lcd in the inner area below the main board.
but if there is just front led light blinking , but no picture or sound then its power supply board problem.
but as you mentioned that the tv turns ON for some seconds then automatically turns off this indicates that the power supply board is not faulty but there is a component on the board that is getting over heated because its got weak so due this overheating of a component the circuit gets short and tv shuts off.
on power supply board there are some capacitors and ic located.if any of the component gets short or budged up then it short the power supply board.so you can check the components on power supply board with multimeter and get it replaced by using soldering iron.
also you can get new replaCEment power supply board.this clears the problem completely.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Feb 20, 2010 | Philips 37MF321D 37 in. LCD Television
50PC1DRA Power Board - defective capacitor location
Hi Zzebra22,
I would suggest to watch the video from the link provided if your TV is behaving the same.
LG 50PC1DA Not powering up clicking sound no picture or sound Diagnosis
Aug 10, 2017 | LG 50PC1DRA 50 in. Plasma Television
I have a z20lcd1 tv and it has no picture
2)the main board .
if there is no power at all them main board is faulty.if no front led light is coming ON there is no power .so the main board is not faulty.on the main board there is a fuse located you have to replace that and check first if still no power main board needs to be checked and replaced
if there is sound but no picture and front led light is blinking then its inverter board panel problem.if this is your case replace inverter panel.its located in the lower side of the lcd in the inner area below the main board.
Nov 03, 2009 | Zenith Z19LCD3 TV
Trips breaker and get "PF" on display even when not tripped
This error code indicates "power failure" was detected. This could be caused by a bad/loose connection at either the logic board, the relay board, or at one of the three main power connection terminals on the back of the dryer. The logic board is located inside the control panel. The relay board is located in the base of the dryer. You can unplug and reseat electrical connections at these locations and check the main power cord hook-up at the terminal block. Hope this helped and best wishes.
Sep 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
PF error on Maytag neptune gas dryer
Aug 30, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
