NAD Electronics 7020e 4A fuse keeps blowing on power up
Hi, My NAD Electronics 7020e amp keeps blowing one of the 4A internal fuses on power up. I am looking for a short but cannot find it. The power amps check good, the rectifier diodes seem okay and I checked most all transistors and diodes and cannot find anything. Any ideas? Thanks.
  • Audio Player... Master
  • 5,193 Answers
Well you are on the right course. I suspect you think the problem is in the power supply and it's probably not. I think that what's gone is either a transistor (or more) or an IC amp - if it uses one - on the main power amp stage. Look at the devices on the heat sink. I think that's where you will find your shorted device.
Posted on Dec 17, 2012
SOURCE: amp blows fuses
The fuses are there to protect the internals of the AMP.....
Please check that the correct fuses are installed......
if the incorrect ones are installed then a fire may develope...
There should be a manufacturers lable on the external chassis that details the fuses to use....
Fuses now days can be slow blow or fast blow....so the correct fuses must be used.....dont increase the fuse rating past the chassis panel label...but make sure they are correct...if they are correct then the amp needs a service to determine where the peak loadings to the power supply are originating from...
Some one may have installed incorrect fuses in the past...
Cheers from YUBEUT
Posted on Nov 03, 2007
  • 4 Answers
SOURCE: NAD 370
Hi There is no circuit breakers inside. close to front panel on a left side under plastic cover is fuse (AGC type) . Before you change fuse look at four filter capacitors in the middle of unit!!! (close to power transformer on pcb) If they are white do not change the fuse and get unit to good service center( it must be someone who knows what they doing!!!) If the caps are different color (black ,purple) you can try to change fuse. Once again if capacitors are white do not use unit-fire hazard!!!! I'm long time service guy for NAD so trust me on this one Dariusz  dariusz70@verizon.net
Posted on Feb 13, 2008
SOURCE: NAD C350
Take a ohm meter and measure resistance from emiter to collector should have a few kilo ohm on output transistor.
If no ohm meter available , remove output transistors from circuit.
note position of transistor . you have a NPN and a PNP for each channel.
Replace fuse and power up. If fuse blows check bridge in the power supply.
80% of the time output transistor burn and blow the fuse.
before replacing output transistors check driver transistors they probably burnt also
Posted on May 04, 2008
  • 24 Answers
SOURCE: I have a teac a717 amp which is blowing both 5A fuses.
Thanks for the clarification. From the fuse behavior and feeding the amp into another amp (generally a no-no) it almost certainly is in the output section. If the amp used output transistors (numbered something like Axxxx/Cxxxx where xxxx=0000-9999) there will be some white three-legged low value (.47 ohm or less) resistors that are probably open. FYI the full part numbers for the transistors would be 2SA/2SC so a part marked C3281 would need a 2SC3281. B+D Enterprises (Google them) has most Japanese semiconductors and they have never sold me a fake transistor.
For more repair tips check out www.audiokarma.org
Posted on Dec 29, 2008
SOURCE: samick sga 120 amp keeps blowing fuses
Fuse blowing is due to excessive current drain and the the first clue is the blown fuse itself. If the fuse blows with a flash a bang and splatters copper across the inside of the glass you have a hard blow caused by a dead short on the power supply, check for power switch flashing over internaly. Short circuit main filter capacitors. Shorted turns in power transformer primary winding. If fuse just separates check for short on output transistors C to E. Try isolating fault by disconnecting LT pos/neg supplies to output stage. Also check for partial shorts on speakers and speaker wires using an analog ohm meter on low ohms setting.
Posted on Mar 28, 2010
Hi ihave nad 304 it keeps blowing 5 amp fuses
Most likely caused by a shorted output transistors on at least one channel + possibly some other components they took with them... but maybe you are lucky and you have a shorted power capacitor or something.
Mar 14, 2015 | NAD Audio Players & Recorders
Dead NAD M15
There are fuse inside Nad M15. If you open the top cove then you can see there are 9 fuses lined up i the circuit board on the right side of the transformer. Check these fuses. Also check is there is any fuse behind the Power one of switch. If it is faulty the replace the same.
Before connecting the power after replacing the fuse. check the working voltage marking at the back side. Is it 120v or 220v. If its 120V then be sure that you are using 120V AC line.
If any fuse blows of when you connect the power then you have to consult any nearest service station.
The Voltage rating and Amps rating of the fuse can find marked up on the two metal strips at the two ends. My be laser mark or punching.
Check the link bellow to see the fuses
Check the 12th picture on the link.
NAD M15
AJIN
Jul 29, 2012 | NAD M15 Amplifier
Massage chair fuse on it keeps blowing Model iRest SL-A08-3L
Get its PCB checked for any shorting or ask a technician to brush up the whole pcb with some alcohol and try 5A fuse instead of 4A. You can also look for latest Jade massager bed Carefit 5000 which is more advanced than a massage chair
Jun 04, 2012 | Health & Beauty
NAD 7020e sudden volume drops, sudden distortion- intemittently
OK. I dont know the answer to your prob, but to let you konw that youre not in this alone, my amp used to occasionly lose considerable volume in one channel. this could be remedied by cracking the volume up to max for a half second or so. (Not a great solution!!) It has finally given up the ghost ...I have lost one channel and the doctor says it wont come back. Not only this but they claim that spares ceased to be sold back in the 90's. having said this I have enjoyed this amp for almost 20 years. I think its time to put it to pasture.
SNO
Apr 12, 2010 | NAD Audio Players & Recorders
Keeps blowing the fuse inside the unit.
When a fuse blows suspect an overload in either the power supply or main amp stage. The most likely cause is some part acting like a piece of wire instead of doing it's job. In the power supply it could be the transformer, voltage regulator, or the rectifier or any diode. In the amp section any semi-conductor on the heat sink.
Check first for burnt or damaged parts. If you have a multimeter any transistor or diode will quickly show up. For when you have the meter on the ohms setting and touch the terminals with the probes, it will show as if you had touched the probes together.
Apr 02, 2010 | ButtKicker BKA1000-4A Amplifier
Receiver had blown 4A 125VAC fuse; is this a fast acting fuse or a slow blow type? Will it matter if I use a 250VAC 4A instead of a 125VAC fuse?
Yes you can use a 250 one. It's the amps that's important. On the other if you can see the remains of a coil on the original fuse then it's a slow blow.
However the fuse might have blown due to a short in the power section or audio section, so make sure you have plenty of fuses!
Jan 09, 2010 | Audio Players & Recorders
Accidentaly switched 12v and ground on amp
NOTHING INTERNAL BUT YOU SHOULD PUT A 30 AMP FUSE BACK IN AS SOON AS YOU CAN TO KEEP THE 20 AMP FROM POPPING THATS THE WHOLE REASON FOR THE FUSE TO KEEP THE ELECTRONICS FROM BLOWING
Apr 05, 2009 | Car Audio & Video
Nad c270 blowing fuses on the stanby pcb
Please do not use a heavier fuse. The fuse is there to protect the unit from damage when there is a problem. Using a heavier fuse will most likely cause further damage. Since the problem seems to be intermittant, it can be a component that is beginning to break down or something as simple as a bad connection internally. If you have no experience working with electronics, I would not recommend you start here.
Something that would help a bit is to see if there is a pattern to when this problem occurs. For instance, does it seem to happen more when the unit is cold or warm? Does it happen more often after being run for a while? These are the subtle clues that will help to narrow down the source of the problem.
Please update this with any additional clues and I'll try to suggest possible fixes.
Thanks,
Dan
Apr 04, 2009 | NAD C270 2-Channel Amplifier
No power at all on NAD C370
User manual here
http://nadelectronics.com/img/manual/NAD-C370.pdf
Read page nine for some simple troubleshooting tips and see if that helps.
It *could* be a fuse but given you've owned it for a while and NAD amps often have capacitor issues in the power supply, chances are it needs some serious work by a good tech. Contact NAD directly and see what they recommend.
Dec 29, 2008 | NAD C370 2-Channel Amplifier
Nad 218 thx power amp keeps blowing ac plug fuse
Hi there. From memory they had bridge rectifier problems with them going short circuit. Check them first. Sometimes the toroidal transformer can go a shorted turn, in turn blowing primary fuses. try to soft start it whilst it is blowing fuses, Best bet is to make up a special lead that has a 60w light bulb wired in series with the mains power supply(or across the fuse holdwer that is blowing:). Limits the power in the circuit to ... well you guessed it 60 watts.
check em out and let me know.
regards
Graeme
Apr 27, 2008 | Audio Players & Recorders
151 people viewed this question
 Grubhead
Grubhead
