Question about Dewalt 12V XRP Battery Pack
Polarity 12v whats the polarity of the terminals on a 12v XRP dewalt battery pack? Thanks!
muttandjeff
  • 359 Answers
SOURCE: drill bit came out, won't go back in. Dewalt 12v XRP
grasp the chuck and put drill in reverse position and pull trigger gently this will open chuck and re-insert bit do same in forward to tighten bit into chuck
Posted on Jan 11, 2009
rowdy45176
  • 2176 Answers
SOURCE: dewalt 14.4 xrp combi drill
remove the chuck retaining screw, shift the tool into the low position and the clutch into the drill only position. Find a bent handle allen wrench about the size of the chuck (bigger the better) insert short end into chuck and tighten. Put the chuck on a work bench with the long end of handle at about a 30 deg angle and hit it with a hammer. It might take a couple times but it will come off. Let me know if you need any more help, and if I have helped you would you please rate my answer accordingly
Posted on May 17, 2009
  • 14 Answers
SOURCE: xrp 18v dewalt drill worked fine with plenty of
if your batts are ok and the batt connection terminals look ok you may have either faulty switch burnt off wire at brushholder or reqire new brushes
Posted on Nov 13, 2009
  • 474 Answers
SOURCE: i have a 18 volt xrp dewalt battery that it das
replace bat.try northerntool.com. i bought a couple of after market ones for mine and so far so good
Posted on Nov 15, 2009
  • 187 Answers
SOURCE: the drill bit came out
I hope I am understanding your question properly, if not, leave a comment. This drill *** a "keyless" chuck. If you look down into where the drill bit goes, there are metal pieces inside the black nose of the tool. Those metal parts are what holds the bit into place. The drill bit slides into the hole at the front of the drill (where it fell out from), Put the drill bit back in and then grasp the black tip (right below where you put the drill bit in). Directly underneath where you put your first hand, hold onto the piece directly below the upper part. Turn the top piece right and left and it tightens or loosens the mechanism that holds the bit in place. Give it a firm turn to make sure it is tight.
Posted on Nov 17, 2009
Why do I get a fast red light on my dw9118 12v charger?
Bad Battery pack, check voltage, try jumping nickel/cadmium battery with car charger, then put on charger.
Apr 25, 2014 | Dewalt 12V XRP Battery Pack
I need to find out where to buy the power terminal fo a 18v dewalt battery
I've been working on cordless tools of many brands for years and there are no individual parts available for batteries from any manufacturer nor any aftermarket parts retailers that I have ever found. Usually if you need these types of parts you have to scavenge them from other batteries.
Mar 04, 2012 | Dewalt DC9096 18V Xrp Battery Pack
I bought new batteries for ,my dewalt dw958 drill and when I put the battery in, the drill ran for about 45 seconds then started to smoke and the drill died. The batteries are dewalt 18v xrp batteris
I am thinking the switch or motor is bad, check the switch first. you can locate parts at dewaltservicenet.com. Make a wiring diagram before removing anything, these parts are polarity sensitive.
Oct 28, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Will a dewalt 12v xrp battery fit and run a 12v firestorm black & decker drill?
Don't know for sure but most batterys are made for each kind of drill.
Jan 19, 2011 | Black & Decker 12V Xrp Drill/Driver
I cannot get the drill bit out.
Needed -2 pair of adjustable pliers.
Hold the chuck with one pair, hold the hand chuck with the other pair turn in opposite directions to loosen bit.
Take care not to mar the plastic on the chuck.
Dec 24, 2010 | Dewalt 12V XRP Battery Pack
Faulty devolt batterie
Try placing the battery in a freezer for six hours before trying to charge the battery and if this doesn't work find a friend with a working charger and make sure using that method that you don't just have a bad charger.
Jul 24, 2010 | Dewalt 12V XRP Battery Pack
Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
Aug 27, 2008 | Dewalt 12V XRP Battery Pack
Dewalt 12V XRP Battery Pack  Logo
63 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
