Av receiver not working
The unit makes a click sound when pressed the power on bottom, like normal amps. But nothing else, no display, no sound.
  • shliu1983 Nov 28, 2012
    There is a click sound when switched off as well.
    Sergeant:
  • 344 Answers
It has develop a internal problem , Will have to be taken in for repair,
Posted on Nov 29, 2012
  • 5 Answers
SOURCE: DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC, AT49LV002-70TC (IC 817 ) at DSP board (Denon P/N: 262 3010 006).
Posted on Sep 11, 2008
SOURCE: Denon DRA-25/25L Stereo Receiver.
Without looking at the schematics for this particular model, I'd surmise that the click is indeed a speaker protection relay. Generally this is fed by a number of different sense circuits that watch for power amp issues and/or excess speaker current and/or power supply output stability. Although the relays do indeed fail at times, generally it is not the relay that is at fault. If you have a scope and a schematic, you can check the various circuits that feed the relay for the exact cause. If not, you can do some experiments that might help deduce the problem: e.g. do headphones work when speakers do not, does the relay click on when no speakers are connected (or selected), etc. In my experience, it is most often the output transistor(s) in the power amp. But not always ;-)
Posted on Oct 15, 2008
  • 4234 Answers
SOURCE: Kenwood Receiver KR-a5020 receiver won't come out of standby
The unit is in what is commonly known as "protect" mode. This means that a problem has been detected in the final output stage of the amp and the outputs are shutdown to prevent further damage to either the receiver or speakers. This should not be a difficult repair for a service shop. Expect a parts cost in the $25-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Nov 28, 2008
  • 4234 Answers
SOURCE: I have a Aiwa Stereo Receiver Av-D58. The sound
If I remember this model correctly, there is only 1 direct input. The remainder of the inputs are bufferred through a switching IC. It is likely that this IC is defective. Are there any other symptoms at all?
Thanks,
Dan
Posted on Mar 13, 2009
palaboy
  • 5807 Answers
SOURCE: yamaha htr-5460 receiver; unit will
I just hope you have read my earlier post if not I will post again
Posted on Sep 24, 2010
Onkyo AV- SR503 WHY DOES IT MAKE CLICK SOUND WHEN I PRESS POWER BUTTON. THEN IT CLICK AGAIN AND TURNS OFF
There are a couple of possbilities here:
1. Make sure you have a good power connection that is not overloaded. If you are using a surge protector, try plugging the amp right into the wall to see if that makes a difference.
2. check all your speaker connections to make sure you do not have a short. The amp may be shutting down to prevent damage.
3. If you cannot find a problem there, what you may want to do is disconnect all speakers and try to turn the unit on. If it starts normally then you know for sure you have a speaker problem.
4 If above does not resolve problem, then unplug all inputs and try turning it on.
If it still does not come on then likey you have a hard fault with the amp and it will require service.
Jun 05, 2015 | Onkyo Audio Players & Recorders
Cambridge Audio Azur 640R AV Recorder won't switch off
Sounds like the unit is victim of a power surge. The power control board is probably damaged. You will be better off replacing the amp as having it repaired will cost more than replacing it.
Mar 02, 2014 | Cambridge Audio Azur 640R 7.1 Channel...
Denon 1312 makes clicking sound will not turn on
If the front display does not light up at all when the press the power button, it is usually either the main power fuse or the power transformer. If the fuse is blowing, that usually means a short in the amp section.
Dec 26, 2012 | Denon Avr-1312 Home Theater Av A/v...
Receiver will not turn on.
check all speakers and wire not short ....if sam problem unit power ouptup amp need replaced
Nov 07, 2009 | Audio Players & Recorders
My Sony STR-DG500 wont turn on just clicks once and nothing.
Sounds like faulty psu (pwer suply unit) Amp is going into protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not psu, sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If on, connect speakers and av cables one by one and test each one on its own until amp switches off, Investigate from there were problem is. Make sure speakerwires is not shorting out.
Aug 29, 2009 | Sony STR-DG500 Receiver
No Sound
when the amp is turned on does the unit make a clicking sound a few seconds after the display lights up.
if not the amp's is not happy with it's power or could have a speaker short. Check the display for a fault warning.
Otherwise check you speaker connections.
confirm that and A and B main speaker buttons are correct.
Try some headphones, if you get sound out of the headphone things might not be too bad, if nothing is output remove all your cables and try again.
Yes I know that can be nasty, so label all the cables first.
Jan 21, 2008 | Yamaha RX-V1500 Receiver
Power on but no display
Hello Coach T, Reset Instructions: 1. If pressing the power button does not turn the unit off, unplug the unit, then plug it back in. 2. Press the power button while pressing the ENTER button. This will bring the unit back to factory defaults. Please let us know if you need any additional help. Best regards, nightdiver
Aug 21, 2006 | Aiwa AV-D57 Receiver
Sudden failure to power up
I've had this happen a number of times with my receiver. This trick from the Troubleshooting guide in the owner's manual usually does the trick: To reset If an unusual condition in the display window or malfunction occurs, reset the unit as follows. 1 Press the POWER button to turn off the power. 2 Press the POWER button while pressing the ENTER button. Everything stored in memory after purchase is canceled. If the power cannot be turned off in step 1 because of a malfunction, reset by disconnecting the AC cord and carry out step 2.
Aug 01, 2006 | Aiwa AV-D77 Receiver
47 people viewed this question
 Grubhead
Grubhead
