Question about Canon F-710 Calculator
What is the exponent key ? - Canon F-710 Calculator
How do i enter an exponent on the
It depends on the base of the power function.
For exponential function use [SHIFT][LN] (e^x) followed by the exponent value. If exponent is negative use the change sign +/- key before exponent.
For a general power, type in the base (number), then press the [Y^x] key followed by the exponent.
For a power of 10, use the [Exp] key. Careful here. For example to enter 1.6x10^(-19), type in 1.6, press the [Exp] key, then the change sign key +/- and the exponent. Press [=]
1 . 6 [Exp] +/- 19 [=]
Sep 28, 2014 | Sharp EL-531WBBK 12-Digit 272-Functions...
How do i do exponent 4
The key you are looking for looks like y raised to the exponent x. It is below the "hyp" key. To determine an exponent, enter you base, hit the y to the x key and enter the exponent.
For example, 3 to the power of 4, enter 3, hit the y to the x key, and enter 4 and hit the = key.
Good luck.
Paul
May 26, 2014 | Sharp el-531x scientific calculator
How to use it for exponents?
To enter exponents (1, 2, 3, -3..) use the general power key marked with Y^x or X^y or ^. Enter the base press the general power key then the exponent. If exponent is negative try enclosing it in parentheses. use the change sign key (-) to enter the negative sign before the exponent.
To enter power of 10, you can use the shortcut key marked Exp (the 10 must not appear when the Exp is used to enter exponents for power of 10).
Feb 24, 2013 | Sharp Office Equipment & Supplies
Where is the exponent key on the 531x
If you mean the key to raise a number to an exponent, it's the key marked "y^x", two keys above the "7" key. If you mean the key to enter an exponent of ten, it's the key marked "Exp", just above the "7" key.
Feb 18, 2013 | Sharp el-531x scientific calculator
Finding exponents key
To enter exponents of an arbitrary base, use the key that is marked [Y^x]
To enter exponent of 10 press the [EE] key. In scientific notation display, the exponent of the power of 10 is displayed to the right of the mantissa.
Apr 08, 2012 | Texas Instruments TI-30XA Calculator
My exponent key does not revert to regular script after i'm done with the exponent. it stays as superscript.
Press the right-arrow key to tell the calculator you're done with the exponent. Otherwise the calculator thinks you're typing in a very complicated exponent.
Nov 16, 2010 | Texas Instruments TI-84 Plus Calculator
Where is the exponent key on Casio fx-115es calculator?
To raise 10 to an exponent, use the 10^x function (SHIFT log). To raise e to an exponent, use the e^x function (SHIFT ln). To raise an arbitrary value to an exponent, use x^y (just above the sin key). To enter an exponent of ten, use the x10^x key to the right of the decimal point.
Oct 27, 2010 | Casio FX-115ES Scientific Calculator
How do you put in the number in scientific notation on the TI 34 II calculator?
Type in the mantissa, then the EE key (for Enter Exponent) above the 7 key, then the exponent. If it's a negative exponent, press the (-) key to the right of the decimal point before entering the exponent.
Sep 03, 2010 | Texas Instruments TI-34II Explorer Plus...
Decimals in the exponents for TI-30Xa
You have a key labeled [Y to the x], use it for all the powers or roots that do not have a dedicated key or key sequence. Let the key be [^]
Ex: 13.675 to the power 1.33 is entered as 13.675 [^] (1.33) [=].
The result is 32.41778634
Ex: (-64)[^](2/3) [=] gives 16 as result. The (-) is the change sign key
Ex: (2.87655)^(-6.778) is entered as 2.87655 [^] ( (-) 6.778 ) [=] 0.0007758
The (-) is the change sign (or the negative of), not the regular minus. When you have a negative exponent or a complicated exponent, it is safer to enclose the whole exponent inside parentheses.
Hope it helps.
Thank you for using FixYa
Nov 21, 2009 | Texas Instruments TI-30XA Calculator
Exponent Sign
To write 50 exponent in math mode, type your number then hit the key that has (x with the solid white exponent key). It's between the (x squared key) and the (log key) then you can enter the number 50 for your exponent. You can also hit the (x squared key) delete the 2 exponent and type in the exponent you want.
Jul 04, 2009 | Casio FX-115ES Scientific Calculator
Canon F-710 Calculator Logo
18 people viewed this question
old marine
old marine
