Question about Juki Sewing Machines
A diagram of how to thread a juki mf890 - Juki Sewing Machines
Zenqi
  • 208 Answers
SOURCE: THREADING FOR JUKI MO 357
Put new needles in it.
Following the colors, thread the upper looper first, then the lower looper. Next thread the needles. Always thread in this order.
Posted on Jun 27, 2009
  • 1116 Answers
SOURCE: Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Posted on Feb 19, 2010
  • 1116 Answers
SOURCE: good diagram showing how to thread a 4 thread Juki
You can download a free threading guide here - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_644_Threading_Diagram.htm
The same site also sells manuals.
Threading Tips:
Have the thread antenna at it's highest position.
Set the tensions to zero.
Have the presser foot up while threading.
When you thread a serger for the first time, or if you are having a threading problem, use a different color thread for each guide. This can quickly indicate where the problem lies.
Once the stitch is satisfactory, change to the color you prefer - but this way is the easiest - cut the thread near the thread cone and tie off with the new thread. With the tensions at zero, slowing run the serger until the new thread appears. You will need to stop as the knots approach the needles and thread them by hand.
Do the tie-off before running out of thread and this will save a lot of time and stress.
Posted on Mar 02, 2010
Tally Girl
  • 1133 Answers
SOURCE: how to thread a juki
do you know what model Juki it is? Is it a serger or a sewing machine? Juki do industrial straight, serger and specialised machines such as coverstitch and blind hemmers as well as domestic sewing machines and sergers so there is a big range of machines.
There are manuals at this site for http://jukihome.com/products/mo644d.html various models of Juki Home sergers, but you will need to hunt through and find your model.
The manual is on the "features" tab for each model so just dig down a bit to locate the pdf file in there.
I hope this is what you were searching for.
Posted on Jun 03, 2011
SOURCE: Need threading instructions for JUKI
I also have a Juki DNU-1541S and I'v had nothing but problems. My bobbin will not feed out thread. The Pressure foot needs a wrench to lift it, the knee pad will not work due to the pressure foot being so stiff. YES, I've turned the knob at the top so much it's near comming off !!
The so-called "Instructional Manual" appears to be a "UNITED NATIONS" resolution in all languages. The English portions is barely enough to fit 1/4 page. A Manual ?? A JOKE is better.
Posted on Oct 23, 2011
Threading diagram for Juki MO.357 overlocker
Search for:
Make Model manual
or
Make Model threading
Mar 13, 2017 | Juki Sewing Machines
How to thread a Juki 2512 3 thread
Perhaps this will help:
Juki MO 2504 2514 2516 Sewing Machine Threading Diagram
there are usually multiple web sites and videos available. Just search for:
Make + Model + the words "Manual" or "threading"
Sep 30, 2016 | Juki Sewing Machines
Threading diagram needed for the looping needles
There are quite a few pictures of threading diagrams on the internet. Just perform a search for the make + model + the word "threading."
Be sure to follow the threading order specified in your owner's manual. If the order is not followed accurately, the machine will most likely not work properly. Also, be sure to RAISE the presser foot BEFORE threading. While threading each thread, grasp the thread with one hand between the thread tree and the tension disk and grasp the thread below the tension disk with the other hand and gently tug the thread to make sure it has seated in the tension disk. With most sergers, the lower looper thread MUST drape over the top of the upper looper in its final threading process Before being pulled under the presser foot.
Juki MO 816 threading Google Search
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiOt_7mqbHKAhVK52MKHc5XB5MQFggdMAA&url=http%3A%2F%2Fwww.raichert.com%2Fadobe%2FMO804-12-16%2520Inst.pdf&usg=AFQjCNH1vfonoEQ29McTsOItvQoW8ECZag&cad=rja
If any either looper thread breaks or comes unthreaded, it is the best advice to unthread all the looper threads and re-thread from the BEGINNING. Just bite the bullet and do it. It will save a lot of frustration.
Jan 17, 2016 | Juki Sewing Machines
THREADING JUKI MO-1516H
Most of the machines have a diagram inside the front cover.
Oct 03, 2014 | Juki Sewing Machines
Do you have a quick threading guide for this
Could not find. Here is one for the 634 that may help - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_634_Threading_Diagram.htm
Raise the thread antenna and loopers to their highest position.
Set the tension controls to zero before threading.
Many sergers have the threading diagram inside the front door of the serger.
Apr 01, 2010 | Juki MO-654DE Mechanical Sewing Machine
I have a Juki MO 3716 and I cannot thread it. Please help. It has four threads.
I also own a Juki MO3716. It is a five thread not a four as it has three lower looper threads. Two are fed through the front, just follow the color codes and the threading diagram on inside plate that you lower to see the threads, the third is threaded through the back and around the left side. I can send email with picture of diagram if needed. the other two threads are for the two top needles. This machine is a true safty stitch with the overedge row of serging and an inner chain stitch row for secure seaming. You can run this machine quite nicely with only three thread ( one inside needle and the two front loopers. If you need further held email me at wanmacinnes@eastlink.ca
May 23, 2009 | Juki Sewing Machines
Sewing Machines Logo
132 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
