Question about Canon ZR100 Mini DV Digital Camcorder
Why wont my camcorder allow my tape to go in
For some reason it wont allow me to put in my tape can you please help thank you
  • 4 Answers
I have the same problem. Let me guess... you put the tape in, it makes a few loud annoying beeps, then ejets the tape. I replaced the battery and it worked fine for a few days, then went back to its old tricks.
Posted on Mar 03, 2008
When i try to record it dosent let mi and in the screen it shows a tape with a line through it. what do i do?
The tape with line through it indicates that there is some issue with tape/tape mechanism. I believe that the tape symbol is as follows:
If the tape warning indicator flashes slowly, the reason may be.
  • The remaining tape becomes shorter than the length of five minutes recording.
  • No tape is inserted
  • The write protected tab on the cassette is set to LOCK(red).
If you're confirmed that the reason is not the first and second, it should be because of the write protected tab on the tape.
Don't worry, I will help you with that. Please see the below picture to view the LOCK slide switch:
If the tape with line symbol flashes quickly, it indicates that the cassette has run out of tape.
If the issue persists, please follow the troubleshooting steps and check if that helps.
  1. Reinsert the tape.
  2. Reset the Camcorder by pressing the reset button behind the LCD panel using a sharp pointed object.
  3. Perform a power resetting
  • Turn off the camcorder. Disconnect AC power adapter. Remove the battery pack.
    Move the POWER switch to the CAMERA position for 15 seconds.
    Move the POWER switch to the OFF position.
    Reconnect the AC power adapter or reinsert the battery pack.
    Turn on the camcorder.
    If the issue persists, service may be required.
    I hope performing the above steps should resolve the issue.
    If you need any assistance please get back to me.. Thanks for understanding.
Feb 17, 2011 | Sony Handycam DCR-TRV250 Digital Camcorder
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
When i try to use my camcorder there's a flashing light with the eject symbol and it wont record or let me use the video
Flashing eject sign error appears when camcorder got problem in its mechanism, please put another tape and check.
Remove battery from camcorder for couple of minutes, put battery back and try.
Also observe does tape reels turns reverse and forward when tape loaded in mechanism.
If problem still exist, qualified camera tech will fix it because it is not user level repair.
Oct 13, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Tape transport stuck in open position. Will not take tape into unit.
It could be possible that the tape is in the wrong way or that the tape is the wrong size those are both reasons that it may not be closing
May 25, 2009 | Canon ZR70MC Mini DV Digital Camcorder
I cant put a tape in!
when mechanism pops out to eject, wait until it completly comes out, deattache battery immediately, and Pull lever as per below mentioned picture. Cassette door will be open and place cassette. Close it and attache the battery. Camera is ready to Record or Playback.
Feb 25, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
I have a Sony Handycam® DCR-TRV350 Digital-8 Digital Camcorder.
did the sony come with any editing software?
If not, then you will have to get some editing software for your computer. Then you hook the camera up to your computer and you can actually control the camera from the software. This will allow you to fast forward, rewind and digitize the video footage to your computer.
hope this helps
Feb 04, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
SAMSUNG CAMCORDER wont recorder
My mom is having the same problem. Trying to find a solution for her. Hope someone can help.
Jan 01, 2008 | Video Cameras
Remove tape error message
  1. Condensation is detected – If condensation is detected by the camcorder, the “Remove the Cassette” warning may occur.
  2. Component failure – If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder.
  3. Sand or grit damage – The camcorder’s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate.
  4. Impact damage – If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur.
  5. Liquid damage – If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation.
  6. Improper videotape insertion – If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual.
  7. Damaged or defective tape – If a tape becomes damaged, please discontinue its use.
Operational Recovery Steps
Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps:
  1. Eject the videotape
    Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2.
  2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry.
Nov 19, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Tape door wont close
I'm having a similar problem. The camera is a Sony DCR-TRV280. When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down. In other words the mechanism works fine without the tape but with the tape it doesn't. I hope the explanation is clear enough. Thanks
Mar 21, 2007 | Sony Handycam DCR-TRV525 Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
97 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
