Question about Dell Inspiron N4020
Vostro desktop will not boot up
  • Dell Master
  • 27,725 Answers
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty.
Although it would be very rare for the sata lead to be faulty.
Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Nov 28, 2012
    Sergeant:
  • 206 Answers
Hi
you need to get a windows installation disk and replace the boot up files that have gone missing.
run disk from boot up and wait for it to complete its install it will ask if you want to install or repair, choose repair.
follow the prompts and then select boot exe this will replace the the boot up files then your pc should start normally.
cheers
Vostro 230 integrated nic
faulty nic, motherboard replacement required or use a PCI nic.
Feb 09, 2013 | Dell Vostro 230 PC Desktop
Dell Vostro 200 goes straight to analog mode/sleep, keyboard, mouse not responding; not booting
replace bios battery, reset the bios, insert required parameters after rebooting and when windows reboot change the time period for screen saver and hard disk shut down!
Aug 05, 2012 | Dell Vostro 200 PC Desktop
Dell vostro orange light and system doesn;t boot-up
Due to certain viruses or faulty drivers your boot image is deleted or prohibited from normal booting.Insert OS setup dosc and repair startup.
or perform a clean installation of OS
Jan 26, 2011 | Dell Vostro 200 Desktop Computer
Dell Vostro 200, freezes, then won't boot
that's a lot of info to work with - start by taking the cover of and blowing the dust out of it.
May 16, 2010 | Dell Vostro 200 PC Desktop
Okay, so everytime i start my Vostro 200(Windows XP) it always shows a blue screen that tells me to restart but it never works, what do i do?
Try starting in SAFE MODE. You may have a virus that kills the booting.
Hit F8 at the right time during booting to get into safe mode.
Dec 12, 2009 | Dell Vostro 200 PC Desktop
My Dell Vostro 1310 won't turn on. I get a black screen (well actually, a bit of colors are coming, but nothing else ...). Tried again and again to turn on, seems to be a problem with the video card....
check for led lights if they come on.
note down the lights.
If you are able to remove the connection of the lcd to the laptop do so for instruction refer to www.dellsupport.com click on manal
Oct 05, 2009 | Dell Vostro 1310 Laptop Computer PC...
Dell Vostro 420 will not boot
If it is booting up to the second window, you might have to re-install your windows
Sep 16, 2009 | Dell Vostro 420 Desktop Computer
Dell Inspiron N4020 Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
