Question about Bose LifeStyle 5 Series-III CD Shelf System
Bose LS5 display dead
I read about this issue, and understand I should replace C19. (the tuner works fine except for the dead display).
but .... how do I remove the covers, so I can get access to the inner parts of the system ?
Thanks,
Leon
  • althoffk
    althoffk Jan 15, 2009
    Same here, how to open the unit and get access to the pcb ?
    Problem Solver:
  • 4 Answers
I have a service manual with complete pcb layouts and circuit diagrams, including dis-assembly instructions, contact me in case someone is interested.
Posted on Jan 16, 2009
  • John Smith
    John Smith Sep 15, 2011
    post the answer to the question...no one wants your spam
FM Tuner not receiving - Yamaha R7 receiver
Take the cover off and look at the cable that connects the tuner to the main board. Make sure it is connected straight and tight. Make sure all screws in the back are tight, just in case it is a grounding issue. Iff all checks out and you still have issues, replace your tuner.
Apr 30, 2012 | Yamaha Audio Players & Recorders
Bose lifestyle 5. Display is erratic when playing cd or radio.
Change capacitor C19 (33uF 63v) next to the dispaly. This capacitor goes leaky over time, and causes ripple on the display which makes it dim or even dissapear completley. Also worth doing all the capacitors near to C19 while your there just in case.
changing C19 worked for me. Some people even up rate the capacitor to 100v, but 63v id the manufacturers reccomended.
Aug 23, 2010 | Audio Players & Recorders
Hi, my Nakamichi Av 10 receiver tuner and the video AUX section is dead and does not work except for the Tape in
I am facing the same issue All Analog inputs except for Tape in does not work and the tuner does not work on my Nak AV-10
Jun 03, 2010 | Nakamichi AV-10 Receiver
No LED Display On The Bose Lifestyle Model 5 Music Center
Hi, you have to replace the 100uf capacitors c14 c15 c16 c17 and c19 on the digital board, that will cure your LED fad problem.
Chris.
Jun 25, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 20 very Dim display
There are instructions available at www.AnyoneCanFixIt.com that has detailed pictures of this repair, step by step.
Jun 23, 2009 | Bose Lifestyle 20 System
Bose LS5 max volume!
you better replaced the volume control it is depected already with identical ratings so it works normal again.. Hope it may helps;;
Jun 08, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Display not working
I think there are some solutions available from www.AnyoneCanFixIt.com for the Bose Lifestyle 20 series with the display issue.
May 26, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Everything works with my bose lifestyle model 5 music center but the display wont light up. Do I have a bulb out or something ? How can I fix this, its driving me nuts! Thanks for any help you can give....
According to other threads this is due to a bad capacitor (either C19 or C16). It is a 33uF capacitor rated at 25V. Needs to be replaced by a 33uF higher voltage (like 63V). Have the same issue but have not yet completed the fix. Please perform a search on the forum and you will find it. It says is on the lower left side of the console pcb.
Dec 20, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 5 ~ dead display fix
Hi the fix for a dead display is a faulty capacitor. Depending upon which board version you have, you need to replace the 33 uF / 63 volt capaitor. On some units this is C19 on the display board, on other units this capacitor is mounted on the main board and re-numbered, there is only one 33 uF on the unit so you should be able to find it.
Dave
Sep 21, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Aug 16, 2007 | Bose Lifestyle 12 System
Bose LifeStyle 5 Series-III CD Shelf System Logo
512 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
