Question about Toys
New bright holiday train does not work when set up. It has hobby transformer A380104148 - 120v/ac. It is a 380 S model. Any suggestions of what the problem might be ?
Not sure it does not seem to get power. It has a Hobby Transformer # A380104148. Not sure how to check if receiving power.
  • 1 more comment
  • Keith Dec 01, 2012
    Ok everyone, first thank you for the comments. I did check the fuse in the transformer, all ok. Now to further try and add to my earlier question on the problem.
    I have figured out that there is power to the control panel which comes from the track connection box . Having said that, the tracks themselves are not getting power. If I am right then the circuit board in the track connecting box may be damaged.
    Any help on how to check this function will be appreciated.
    Thanks,
    Keith
    Thanks,
    Keith
    Thanks again for your help, after checking out all suggestion it came down to dirty contacts on the track clip and the tracks themselves. After cleaning with a fine sand paper and oiling the contacts on the wood tinder that plugs into the engine all work s great.
SOURCE: My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Posted on Dec 08, 2008
  • 14 Answers
SOURCE: I believe my New Bright Holiday Express train set
Yes they do. I have the #380-2 Water Tank car (and the other 4 that are available) They run and operate just as the other cars do.
Posted on Dec 16, 2009
Testimonial: "Thanks for the quick reply. This will really help!"
SOURCE: Need Z4000 transformer (trains) manual
We were able to locate a Z4000 transformer manual. Found out our problem was a connection problem with the track and not a problem with the transformer. Thanks anyway.
Posted on Jan 01, 2010
SOURCE: I have an HO scale
Check the engine motor and second car motor with a digital multimeter for continuity. Make sure the track is connected properly. Also probe the transformer and see if it is sending out power to the track
Posted on Dec 20, 2010
GodBlessU
  • 3513 Answers
SOURCE: I have two 380 Holiday
Sorry to say but New Bright does have these replacement parts hence you need to try hardware stores to see whether you can get a similar adapter . Check the V and the power it should not be an issue.
Thanks
Posted on Dec 24, 2010
New Bright Holiday Express train No. 380 won't run or even light up
You need to fault find with a multimeter before guessing what to change.
Dec 22, 2017 | Televison & Video
I have a New Bright 1997 holiday train set and it just quit working a few years ago. No power. I even replaced the transformer with no luck. In both transformers I only measure about 2 volts coming out...
Is the transformer getting hot? Sounds like there might be a short circuit in the system. You'd need to put an ohm meter across the tracks (or a Digital Multimeter (DMM) set to ohms) to verify the short and then look around for some electrical path between the tracks.
Nov 26, 2017 | Crafts & Hobbies
WERE I CAN BAY A HOBBY TRASFORMER FOR A ELECTRIC TRAIN NEW BRIGHT QUALITY TOYS
All electronics have all kinds of transformers. Many surplus stuff and economically priced.
Nov 18, 2014 | Electrical Supplies
New bright greatland holiday express train
Check the connection from the transformer to the track, and that all the track is well connected. Make sure nothing is touching both tracks, shorting them out.
Nov 25, 2013 | New Bright 384 Holiday Express Animated...
New bright santas christmas express no, 187 train wont smoke
This goes back about 40 years for me. Both Lionel and TYCO had "smokers" in their train sets. My recollection was that the "special smoke oil" was a mixture of very highly refined kerosene and parafin wax. Try a hobby shop such as Hobby Town or some such.
Nov 27, 2012 | New Bright 384 Holiday Express Animated...
We are having difficulty turning on our New Bright Holiday Express Animated Train set. Husband and I have been trying to figure this out for our eager 2 little boys. The remote seems to turn (red light)...
Here are a couple of resources from New Bright:
http://www.newbright.com/public/electric-train-faq
http://www.newbright.com/images/Manuals/384%20ws%20manual.pdf
There is no On/Off switch on the train. Power goes from wall plug to transformer, then from transformer to track clip, which must be attached to the track. A control line goes from the track clip to the controller. Mine has a green light just above the red On/Off button that will come on even if the engine and tender are not on the track. The tender does all the work, and must be connected to the engine and on the track. There are four sliding contacts between the tender wheels that provide contact with the track.
Dec 09, 2010 | New Bright Small Holiday Express Train
Each yr my New Bright Holiday Express train gets slower and slower the longer it runs. Finally it just stops. Every thing else seems to work: lights, etc.Train shop specialist say its the engine, not the...
check the electrical current to the trans former , then check the out put from transformer, may not be getting adequate electricity flow to operate , and if you continue to operate under required current , it may damage engine and or transformer , gd luck
Nov 23, 2017 | New Bright Small Holiday Express Train
Need train transformer model #APX663004
mcdevito75 here, Contact New Bright online at www.newbright.com for the transformer. Hope this helps. I didn"t see a telephone number at the site. Sorry.
Jul 13, 2010 | New Bright 384 Holiday Express Animated...
I have a new bright animated holiday train from a garage sale and I think I am missing a power cord
You should have a 3 pieces to provide power....
1. A track connector box. Looks like a "T". It slips under the track to make the track power connection. The transformer plugs into it (2 pin Molex type connector) and the command console (has an RJ11 telephone jack type connector on it)
2. A large square transformer. One end plugs into the wall and the other into the track connetor box.
3. The Command Console. Has the on/off button, forward, reverse, mute, sounds and speed contol on it .. has a connector that looks like a telephone plug.
Unfortunately... DO NOT look to New Bright for missing or non working parts. New Bright does not offer repair or replacement parts for thier products. :-( ....
Dec 10, 2009 | New Bright 384 Holiday Express Animated...
Toys Logo
142 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
