Question about Empire Comfort Systems DV35IN33L Natual Gas Direct Vent Large Fireplace Insert 35K
Empire DV35 is making soot
I replaced the burner unit on the DV35 and now it makes soot which coats the pilot light and the external direct vent fins in about 1 -2 days of use
  • 2,878 Answers
OS for computers. Try another post. gl.
Paul Rogers as in Bad Co?
Posted on Nov 28, 2012
Replaced thermocouple pilot stays on but burner wont light
Make sure the gas valve dial is turn to the "on" position. Otherwise, I would need more info to answer this question fully.
Nov 17, 2015 | Empire Comfort Systems DV-215-SG...
My dv35 wall furnace pilot light on main burner will not light
lightly tap on the area where the wires are connected. the valve will stick at times. try that.
Oct 30, 2011 | Empire DV-35 Heater
Hi there my home is about 3 years old. i have noteced black dust on the doors window frames basically everywhere. i don't know why.
Does this unit have an blower? If so there is no filter and this can happen.
Direct vent means no open flame in the house but you might still have a combustion problem. Open the front cover and check for black soot. Also check outside at the flue for soot. If so then you need to get this thing checked. Also make sure the little door for the pilot is closed. May have a improper install here if only 3-years.
Sep 05, 2011 | Empire DV-215 Direct Vent Natural Gas...
I've got a 23 yr old 30DV3 whose pilot light works, and the thermostat & heating element seem to work, but not well. With the thermostat set at full hot, it just barely throws out any heat at all. ...
As I'm sure you already know, Empire Comforts Systems, no longer makes that model heater and hasn't for some years, now. I mentioned that, because if your unit needs parts, they may be almost impossible to get. In any event, there are a several things that may be causing the problem.
  • Low Gas Pressure - Burner is not receiving enough gas. Check for obstructions and have gas pressure at the unit checked.
  • Clogged burner or air intake (venturi valve) is partially clogged. Clean burner ports and venturi valve.
  • Gas line Shut Off Valve at heater not fully open. Check Gas line Shut Off Valve.
At 23 years old, you've gotten your money's worth out of this unit and it may be time to replace it. Empire makes several Direct Vent Wall Furnaces that are rated as High Efficiency Furnaces. In the long run, the money saved in fuel cost, would be worth installing a new one.
Hope this helps you solve the problem.
Apr 11, 2011 | Empire Direct Vent Wall Furnace;...
What causes black soot to smoke up our complete house with ventless logs
Take the pilot and burnner assembly all apart and blow it out with compressed air then reassemble and make sure that the air shutter is totally open. The soot is cause by a bad air/fuel misture that is too rich and cause carbon to form from incomplete combustion. If the burner continues to make soot then reduce the gas pressure to the gas log at the pressure regulator.
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 24, 2010 | Empire DV-215 Direct Vent Natural Gas...
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
Empire GWT-50 creating soot and sometimes flashs when starting
if it giving off soot then it is wrong it sounds like the air mixture is wrong and the flames are light back to the injector that would be the woosh , no heat er should give off soot if combustion is correct
Jan 09, 2009 | Empire GWT-50 Wall Mounted Panel Heater
Light soot around propane fireplace vent
burners burning yellow , in complete combustion , blocked air ways to burner , it needs a service soon as poss
Dec 22, 2008 | Empire DV-215 Direct Vent Natural Gas...
Pilot lights and one panel burns
Empire faw 40 makes a loud bang when starting up. There are three burners. The pilot light is on one burner. When the furnace starts, gas is lit on that burner and the flame is passed on to the other burners by a small channel that can get stopped up. You just have to remove the burners and clean the channel with a small file, like on a finger nail clipper. This can be difficult due to the pilot assemble being attached with two bolts. The bolt on the right has to be removed with a short screw driver. You can not get a socket on it. After you remove it there is enough play to remove the bracket and gas burners.3_4_2012_5_06_50_am.jpg
Nov 23, 2008 | Empire DV-215 Direct Vent Natural Gas...
Pilot will light, burner will not light.
check all limit switches to see if they can be reset if so reset it ,if problem reoccurs wich limit is going out ? make sure all wires are connected well to your gas valve , use a low voltage tester to make sure your firing circuit is operating properly , if you have a thermocouple it may not have enough juice left to open your gas valve
Nov 02, 2008 | Empire DV-215 Direct Vent Natural Gas...
Empire Comfort Systems DV35IN33L Natual Gas Direct Vent Large Fireplace Insert 35K Logo
54 people viewed this question
Top Empire Comfort Systems Computers & Internet Experts
David Payne
David Payne
Are you an Empire Comfort Systems Computer and Internet Expert? Answer questions, earn points and help others
