Question about HP LaserJet 3600n Printer
HP Color Lserjet 3600
HP Color LJ 3600 Printer continue. Calibrating And Not Ready For Print
  • Anonymous Feb 14, 2009
    Calibrating And Not Ready For Print ....
    cONTINOUS CALIBRATING .
  • Anonymous Feb 18, 2009
    THE PRINTER COLLABARATING WHEN INSTALLING THE MAGENTA CARTRIDGE
We found that we had a defective cartridge. We returned it. A replacement cartridge did not cause the printer to callibrate continuously.
Posted on Mar 26, 2009
My HP color laserjet 3600 printer continue calibrating, I can't do anything.
Try unplugging the printer. Remove the cartridges. Switch the printer back on and insert the cartridges.
If that doesn't work, remove the cartridges, unplug, put the cartridges back in and plug back in.
One of those should reset. If not, there is Support, including Chat on the HP site. Nice printer!
HP Color LaserJet 3600 Printer series
Nov 18, 2015 | HP Office Equipment & Supplies
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Hp laserjet 3600 printer Won't stop calibrating, i try to change toner,reset dafault settings,still calibrating,i canot stop calibration,can u pl sent gud solution. Thanking U shiju
Its a particular problem with this printer, it needs a firmware update.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=1
May 29, 2011 | HP LaserJet 3600n Printer
Cannot stop my HP Color Laser jet 3600n printer from calibrating
Use service mode to skip calibration on startup. Then perform quick calibration when ready.
Dec 23, 2010 | HP LaserJet 3600 Printer
My hp colourlaserjet printer (model : 3600)
if you go into the printer menu you will find that it can be set to calibrate at diffirent times. eg start up
Mar 01, 2010 | HP LaserJet 3600n Printer
HP LaserJet Color 3600 The blue color is very bad I changed the blue cartridge and the same Now after one day the printer stay in ''calibrating status for a very lont time''
you should try the SOLLUTION 5
This is an answer to most of the problems of "continuous calibration" in the HP 3600.
When the printer begins to constantly calibrate and falls in line so we have a problem, there are several causes for that problem and must be discarded from the simplest solution to the most complex.
Let's begin:
SOLUTION 1: The first thing to do is turn off the printer, and remove the cartridges, toner dirty or if the internal parts of the printer remove the excess, if there is dirt in the transfer belt clean.then close the front cover and turn on the printer without cartridges. then open the lid, place the magenta cartridge, and close the lid again, and so putting the four cartridges. If the problem persists try the next solution.
Solution 2: We must be alert to any strange noises in the printer, it is likely that one of the sticks is failing, if we are a strange noise came from, and replace the cartridge.
SOLUTION 3: There are times that it is software problem can be solved with a "COLD RESET" to do this we must turn the printer, and press the green button several times in the main menu until you see some options, navigate to the Down Arrow button until COLD RESET appears, press OK. the printer will restart and initialize. then restart and probably reached OK status.
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement due to "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." is in the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=0
SOLUTION 5: If any of these options serves, it is likely that the mirrors of laser printer are dirty, this requires us to print a sheet to observe defects in print (moved, blurred, misplaced shadows), if any of these defects appear we disassemble the printer for cleaning the laser ... in this link are instructions
http://translate.google.com/translate?js=y&prev=_t&hl=es&ie=UTF-8&layout=1&eotf=1&u=http://ingenioysoluciones.wordpress.com/2010/04/12/limpiar-espejos-de-the-printer-hp-3600n-to-edit-print-defective / & sl = en & tl = en
Feb 12, 2010 | HP LaserJet 3600n Printer
Have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? thank sin advance.
600 Hp Continuous Calibration 1 Votos
This is an answer to most of the problems of "continuous calibration" in the HP 3600.When the printer begins to constantly calibrate and falls in line so we have a problem, there are several causes for that problem and must be discarded from the simplest solution to the most complex.
Let's begin:
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement due to "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." Is in the following link:
http://ingenioysoluciones.wordpress.com/2010/04/12/limpiar-espejos-de-la-impresora-hp-3600n-para-corregir-impresion-defectuosa/
May 26, 2009 | HP LaserJet 3600n Printer
Hp Color LJ 3600 continue. Calibrating
Had a similar problem with a customer's printer. HP tech support had me change out the environmental sensor and the boards, this did not fix problem. In the end we had to get a replacement printer (thankfully the unit was under warranty)
Jan 10, 2009 | HP LaserJet 3600n Printer
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
Oct 02, 2007 | HP Color LaserJet 9500HDN Printer
HP LaserJet 3600n Printer Logo
918 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
