Question about Canon Powershot Sx240 Hs 12.1 Mp 20x Camera Blackbundled 5gifts1 Year Warranty
ImageBrowserEX won't load past 80%
Just bought new Canon point-and-shoot and downloaded the provided software which included ImageBroswer Ex. It downloaded fine but then when I try to open the program, it only starts up to 80% and then I get an error message that says "failed to load properly.Verify that Silverlight is properly installed and start Image Browser EX again". I've checked Silverlight, even tried uninstalling and then reinstalling but nothing will work??
  • 1 more comment
  • lacibu Dec 06, 2012
    Exactly the same problem here!
    ImageBrowserEX won't load past 80% /Windows Vista Canon 650D
  • Ole Lund Andersen
    Ole Lund Andersen Aug 18, 2013
    Don't know if you allready solved the prob. But I had same prob. and this solved it:http://www.justanswer.com/printers/7wvua...
    New Friend:
It is important, that you ALLOW in the InternetOption of IE the ActiveX
- Run ActiveX controls and plugins
Posted on Dec 29, 2012
    New Friend:
I solved the problem with deleting the imagebroser database
with IBX_DBcleaner.exe
Posted on May 16, 2014
    Problem Solver:
  • 12 Answers
Method 1: Silverlight Clean Installation
Step 1: Download Rkill from the below link and run the Rkill and end the suspicious process in the computer
RKill is a program designed to terminate malicious processes currently running on the computer.
Note RKill Just terminates the process and doesn't remove the virus.
http://download.bleepingcomputer.com/dl/8c2544a82f5fc3f2ecc3d10f91a71ff8/519ded
d1/windows/security/security-utilities/r/rkill/rkill.com
Save the Rkill.exe on desktop.
Double-click the Rkill icon and run Rkill.exe
You will see a black MS DOS dialog box. Rkill will terminate the unknown processes
It will take several minute before a Notepad file containing log information on what Rkill
found will open.
Check for any unknown processes running directly from Appdata or Temp folder or
Program Data C:\Users\<User Name>\AppData\Local
C:\Users\<User Name>\AppData\Roaming
C:\Users\<User Name>\AppData\Local\Temp
C:\Documents and Settings\<User name>\Application data (Windows XP)
Do Not Delete any content inside Appdata local folder the subfolders other than Temp. Delete the files only if it is detected and closed by Rkill that is loading from APPdata Local folder directly or Temp folder or Roaming folders
Delete harmful process (mostly EXE, CMD, bat, DLL files) loading directly from Appdata Local folder
Step 2: Use Fixit tool to uninstall the silver light from the computer.
Microsoft Silverlight Fixit
http://download.microsoft.com/download/6/C/9/6C970550-32AB-4235-9CDD-
7FC9DD848BBB/silverlight.diagcab
If the above fixit fails for any reason Use the below mentioned Batch file to remove the Silverlight
completely
File Name: Silverlight removal
Step 3: Windows Install Uninstall Fixit
Microsoft installation and Uninstallation issues Fixit
Download the Fixit from the Below Link
http://support.microsoft.com/mats/program_install_and_uninstall/
Execute the Downloaded Fixit file
Select Detect Problems and let me select the fixes to apply
Click on Uninstalling
Select Microsoft Silverlight and Click next
Select Yes, try Uninstall
Step 4: Install Silverlight in the computer using below URL
Download Latest Version of Silverlight from the Below Link
http://www.microsoft.com/getsilverlight/get-started/install/default.aspx
Double click on the Downloaded file to initiate Silverlight Setup
Launch the Nx Browser and check.
Method 2: Perform clean boot in the computer and reboot the computer.
Method 3: Repair Canon Image Browser
Repair the Canon Image Browser from the control panel in the computer. ** After the initial database file has been deleted, a new database file will automatically be
created by ImageBrowseEX the next time it is started. This operation may take some time.
This completes the procedure for deleting the ImageBrowseEX database file
Open the ImageBrowser EX folder and delete Image Browser EX database from the
computer.
ImageBrowser EX is saved to the following location by default:
[Computer] > [Local disk (C:)] > [Program Files(x86)] > [Canon] > [ImageBrowser EX]
Double-click [IBX_DBcleaner] and delete the database.
NOTE
Depending on the settings of your operating system, [IBX_DBcleaner.exe] may be displayed
Start Canon ImageBrowser EX and check.
Method 4: Reinstall Image Browser
**NOTE: Before Uninstalling the Image Browser, confirm the customer has the installation
disc IF NO DISC note version of the Image Browser which is installed in the computer and
download the file FIRST and then Proceed to Uninstall and reinstall the Image Browser in
the computer
Image Browser different version with respective to the Operating System can be
downloaded from the below URL:
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/software_applicatio
ns/imagebrowser_ex#DriversAndSoftware
Once the Download gets complete proceed with uninstalling and reinstalling the Image
Browser in the computer.
Step 1: UNINSTALL
Before uninstalling ImageBrowser EX, confirm that all open programs have been closed
Uninstall from the Add/Remove programs.
Select [Canon Utilities ImageBrowser EX], and then click [Uninstall/Change] and uninstall
the Image Browser from the computer.
Restart the computer.
Step 2: REINSTALL
Insert the EOS DIGITAL Solution Disk into your computer IF NO DISC run the setup file
while which is downloaded before.
Before launching the Image Browser delete the ImageBrowser EX database file, and then
try launching ImageBrowser EX.
Follow the Method 3 in the KB to delete the image Browser EX database file in the
computer.
Method 5: Create New User account
a. Create the new user account which is of having Admin Privileges.
b. Try installing Canon Image Browser Ex
a. Install the Alternative software for the Canon Image Browser like and inform the customer
to use the alternative application to view the images and videos.
EX: Zoom Browser, Photo Gallery.
You can download the Zoom Browser from the below link and can inform the customer to
use the alternative application.
http://www.bildecke.de/files/zoombrsr22.exe
Posted on May 14, 2014
    New Friend:
  • 7 Answers
Follow link it fixed the problem for me:
http://answers.microsoft.com/en-us/windows/forum/windows8_1-hardware/canon-imagebrowser-ex-not-working-in-win-81-64/efde32e6-3971-45d8-9748-4303c528517c
Posted on Nov 17, 2013
  • Nick in Houston Nov 17, 2013
    tap on link it fix problem for me:http://answers.microsoft.com/en-us/windo...
2 Suggested Answers
ardmax
  • 155 Answers
SOURCE: Zoom Browser EX software always fails to install on my Sony Vaio laptop
Reading wht you are saying I agree that the problem is not the camera, cable, CD, etc... but your PC.
I assume you wife's computer is also running on Windows XP.
Can you verify that you have the administrator rights on your computer? Go under Start, Settings, Control Panel, User Accounts and be sure that close to your name is saying Administrator like in this example 1ebbf22.gif Another things to verify is that you don't have The Windows firewall blocking your application, again go under Control Panel and temporary disable it.
Last but not least use the ZoomBrowser 5.8 or higher.
Let me know the result.
Posted on Oct 24, 2007
How can I load pictures from my Powershot A40 to my computer with Windows 10?
Two ways.
Connecting to the computer via the lead, you should open Windows File Explorer and you will see the storage in the camera as a removable storage
or
you go to the Canon website and get all the software including the download software and add-ons. The Win 7 software should be good on Win 10 and includes ZoomBrowser and PhotoStitch.
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/support-point-and-shoot/powershot-a-series/powershot-a40
Mar 26, 2016 | Canon PowerShot A40 Digital Camera
ImageBrowserEX downloaded but will not load past 80%
Hi
I would google the problem to see if other people have had this issue and if they were able to resolve it i would also email or call the manufacturer of the product and ask them for some tech support as you cant be the first this has happened too.
cheers
Nov 27, 2012 | Computers & Internet
I think I need a new installation disc for my Canon PowerShot SD850 IS. I don't have one. When I connect my camera it shows that is downloading the pictures then it shuts off my camera and said it...
just down load it
and then you click on the downloaded file and it should install the software.
the link below will automatically detect the windows operating system you are using if you are using windows
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/support-point-and-shoot/powershot-sd-elph-series/powershot-sd850-is?tab=drivers_downloads
Sep 04, 2017 | Canon PowerShot SD850 IS Digital Camera
Cant figure out where batterys go
It may be the canon camera software problem,or the canon battery output wire have some problem,that will be a trouble matter.Good luck.
May 14, 2010 | Canon Sure Shot 80 35mm Point and Shoot...
Is possible to get a FREE manual for the Canon IXUS 80 1S?
Go to http://.www.canon.com, select your country, then "Downloads". Follow the prompts and you should be able to download the manual for the camera.
Jun 13, 2009 | Canon IXUS 80 IS Digital Camera
Used g5, new owner, problems finding codec or interface with xp
what operating system are you using? BTW, I usually use a card reader to retrieve my photos. G5 is a awesome point & shoot!
Nov 11, 2008 | Cameras
Can,t download to vista
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Oct 26, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Not taking Pictures
The camera needs to be loaded with film.
Needs new battery
Apr 02, 2008 | Canon Prima BF-80 35mm Point and Shoot...
Canon Powershot Sx240 Hs 12.1 Mp 20x Camera Blackbundled 5gifts1 Year Warranty Logo
4,275 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
