Question about Plumbing
Sears 12040 floor jack/repair kit
The piston seal is bad on the 2 ton floor jack. looking for replacement seal or part number to search for. Thanks
  • 89 Answers
SOURCE: Sears model # 875.501390 floor jack will not raise at all.
IT SOUNDS LIKE IT IS CAPABLE OF MOVING FLUID FROM THE RESERVOIR TO THE CYLINDER. CAN YOU SEE THE SMALL PUMP PISTON POP BACK OUT WHEN PUMPING THE HANDLE? MOST JACK PROBLEMS BELIEVE IT NOT IS AIR. THEY GET AIR POCKETS IN THEM AND CANT PUMP THEM OUT. TRY REMOVING THE FILL PLUG ( TYPICALLY A SMALL RUBBER POP-IN CAP ) FROM THE CYLINDER AND JACK IT UP. IF THIS WORKS DO IT FEW TIMES, THEN REINSTALL THE PLUG. YOU COULD ALSO HAVE A SMALL CHECK VALVE PROBLEM INSIDE. IF YOU DISASSEMBLE, BEWARE OF SMALL SPRINGS AND CHECK BALLS. MAKE NOTES. HOPE THIS HELPS.
Posted on Apr 07, 2009
erickg
  • 116 Answers
SOURCE: replace side pump seal and wiper
the cup side of seal goes towards the pressure side.
Posted on Apr 16, 2009
erickg
  • 116 Answers
SOURCE: Floor jack will not raise even without load
sounds like either pump piston seals or check valve on pump.
SOURCE: hi i have a 3 ton sears floor jack i can not
I think I have the same jack. Th serial number was on a little sticker that is long gone,but the model number you need might needs is: 875.501390.
Hope this helps.
Gary
Posted on May 02, 2009
SOURCE: jacks stalls 1/2 way up
try opening the hydrolic oil "fill" plug to let air in...Your jack came with a vented plug,for you to put on after shipping...so oil doesn't leak while being transported...I hope this helps,...1nglen
Posted on May 23, 2009
How to overhaul/ repair a hydraulic floor jack?
Sounds like a bad seal on that plunger that pumps up and down. That plunger should unscrew and then it's pilled out , there should be an O ring. That is where it probably is leaking. You probably need to top off oil. You can jack oil in an auto store or Lowes, etc.
Jun 08, 2014 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
Sears 11/2 ton floor jack
Is there anywhere that you can tighten the seal retainer if not needs a new seal . My experience is that a seal kit is as expensive as buying a new jack plus the work that goes into it. Look up how much to buy a new one and a set of seals then decide
Oct 21, 2013 | Washing Machines
I have a old 1.1/2 ton sears floor jack model is 328.12001
dont think seals will be available ,where it lock down to stay up is a ball bearing in a seat and this is worn .
May 07, 2012 | Cars & Trucks
My floor jack wont go up like it should it does go up but real slow and thean it creaps down and it has no leaks its a 3 ton crashman floor jack
Someone has likely overtightened the the handle valve and distorted or cracked the ball or seat to where it will no longer seal. If you can provide a model number we might be able to find a parts diagram and see if it is repairable.
Apr 19, 2011 | Home Fencing
Jacks stalls 1/2 way up
May 04, 2009 | Plumbing
Apr 02, 2009 | Plumbing
Hi i have a 3 ton sears floor jack i can not
Hope this helps.
Gary
Mar 01, 2009 | Plumbing
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
1-800-221-9705
John
Sep 27, 2008 | Plumbing
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
