Question about Refrigerators
I have a samsung rfg295aawp fridge. my compressor fan isnt working. i replaced the fan is there different fans with different plug ends?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Yes there are.
Posted on Nov 28, 2012
Krazytech
  • 725 Answers
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Posted on Aug 18, 2007
  • 87 Answers
SOURCE: fan for amana fridge
Not sure of the description of the fault. If you are saying that the internal fan will not run but that you have put a power supply to it and it has run, it could be a number of possibilities... You described moving the cabinet. It is highly possible that a pipe or part of the refrigeration system has been damaged in the move and caused a loss of gas. If you remove the back panel to expose the evaporator (cold coil), and turn the system on, after 5 to 10 mins you should see a frost build up over the whole of the coil. If you dont then you probably have a leak. Result call a fridge guy. Leaks can vary in cost and is entirely dependent on where the leak is located and how long it takes to find it. If it does freeze the whole coil then you may well have a problem with the defrost heater or defrost thermostat. Both of which need to be intact in order to provide a neutral supply to the fan motor. You can (IF COMPETENT) check that you have resistance across both of these elements. If you have an open circuit on either then that is your problem. (PLEASE REMEMBER THAT THE DEFROST THERMOSTAT HAS TO BE BELOW 0'C IN ORDER TO HAVE ZERO RESISTANCE ACROSS IT...I.E. COIL COLD). Hope this is of some help.
Posted on Sep 08, 2007
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
SOURCE: Samsung fridge freezer
Hi I have same problem as gordon. fridge 5 years old.
Posted on Mar 02, 2008
SOURCE: noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
Posted on May 27, 2009
Hi i have a wirlpool fridge the freezer and fridge works fine but it seems the motor keep on running and dont switch off or is it the fan that is running please help
Hello Sandra;
My name is Peter. I am a retired field service refrigeration technician.
You just have a simple operational and maintenance issue.
Neither your compressor or fans should run continuously.
First, you need to clean your condensing coil. You did not provide a model number so you either have a flat cooling coil in the front bottom, or a canister type in the back right hand side. This coil dissipates the heat. If it is plugged up your compressor and fans will run trying to keep up with the unit temperature settings. This can make a difference as much as 40 degrees. The toe plate, bottom front is either held in place with a screw on each end. If no screws, there is a clip on each end. Just pull and it will pop out.
Second, You only have only one cooling source and that is your freezer. The freezer will try to satisfy itself first before the fresh food section. If you set the temperature controls beyond the unit design settings your compressor and fans will keep running. Set your freezer to -2 or +2 Deg. F., and set your fresh food section to 35-40 Deg. F.
Third, Check your door gaskets. make sure there are no gaps.
Dec 21, 2014 | Whirlpool Replacement Refrigerator...
RF267aewp french door refrigerator is acting crazy. Sometimes compressor fan runs, sometimes it doesn't same with freezer fans. Front control panel will not respond so I cannot get into diagno
Had same problem on my fridge a long time ago. Here is what was wrong on mine. Debris had clogged up around the fan blades to the point where the very small motor that runs the fan was not powerful enough to make the fan turn. When this happens the compressor has to work harder and harder until it finally shut down on safety cutout. I had to open the back of the fridge and clean up the fan blades, [ took the opportunity to put a small amount of oil on the fan shaft too, my Norge fridge is now over 50 years old.]
Nov 05, 2014 | Samsung RF267AEWP - 26 cu. ft. French Door...
Rl41WGIH fan on but no light and fridge isn't very cold
Bad news for you. I've had the same symptom. The problem was compressor. It seem it will not work longer as about 5 years. To buy another one and repair was expensive. I have now new fridge similar to this but I hav for compressor 10 years waranty.
Mar 29, 2014 | Samsung RL41WGIH Bottom Freezer...
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Hi there, I have a Samsung RS21DCNS F/F. and have just moved house and connected it all back up. The LED display lights up, but the fridge and freezers won't cool and there's no motor or fan...
Was the fridge laying down? How long? Rule is if a fridge is laying down for an hour leave standing for a minium of an hour WITHOUT PLUGGED IN. ^hours laying equals 6 hrs standing. I tell everyone give it 24hrs of standing to eliminate problems. If you plugged it in without enough time for the oil in the compressor to return back to the compressor you may have fried your compressor. Now if you did leave it long enough and the oil in the compressor got back in compressor before plugging in. It could be in your defrost timer or your start relay. Does the fan in freezer come on? Push the switch to make the fridge think door is shut. If fan does not run it sounds like the defrost timer. If fan does run the check the start relay on compressor. Does the compressor turn on? Do you hear a clicking sound coming from copressor? If you hear a clicking noise than its your start relay trying to come on. Replace start relay and overload. The model number you gave me is not valid so get the full model number and check thru Searspartsdirect.com
If you need further assistance please feel free to contact.
Jul 24, 2011 | Samsung Refrigerators
Samsung Refrigerator RS261MDPN starts up when plugged in for about 10 seconds then stops. The center light of the freezer temp indicator blinks. compressor does not run in this mode. Also,is the...
Samsung fridge wont start compressor right away. There is delay, so when you plug fridge in it take 15 - 20 minutes to start.To check if fan is running, you need magnet. Place it on top of door hinge. Open door and if lights are out, you are in wright spot. Take magnet of to test if lights come on. Now put magnet back and if fridge fan is running you can feel it how it blow from different outlets inside of fridge .
Jul 23, 2011 | Refrigerators
Both fridg and freezer not cooling down. Diconected damper wich was continualy trying to close heard Evap. fan trying to kick on surge surge surge
well u answered ur own question if the evap fan isnt running then the compressor is overheated check the fan and make sure that the fridge isnt froze up unplug it for a few hours and plug it back in and see if it will cool for a while
Jan 22, 2011 | GE Refrigerators
Fridge cools short time and stops
sounds like the condensor fan isnt running. I would replace the fan if thats the case. If the fan is running then you have a overload problem or a bad compressor
Aug 02, 2009 | Refrigerators
Slow compressor fan
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
Jul 22, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
