Question about Mag Innovision InnoVision XJ 717 Monitor
Red words under the words
My ig screen sony videoscope xbr is looking like it is out of alignment with the red on the left top hand corner for the screen. Lets say I was watching ESPN and it will so the ESPN logo on the top left hand corner and under that there will be a red line with a red word ESPN also. There are some all over the TV but just not as bad as the top left hand corner.I have try to cleans and lense but don't know what to do. Please help because I am clueless.
  • likemysi Jan 15, 2009
    can you explain to me what that is so i can replace it
  • 535 Answers
Ptc or decosing coil is bed or notworking proper so u have replace it
Posted on Jan 10, 2009
Is there a way to adjust the picture size? On some channels the picture is cropped at the bottom.
this is an aspect ratio problem ans is corrected /adjusted on the on screen menu
use the remote to achieve the on screen menu and scroll around until you find aspect ratio
use the volume buttons to select and adjust
Apr 27, 2015 | Sony 40" FD Trinitron WEGA XBR Hi-Scan TV...
Sony videoscope xbr
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Feb 25, 2014 | Televison & Video
Hi. My Sony Videoscope XBR's Convergence Allignment
I happen to share this same problem. The alignment of the gridlines on the standard convergence panel are completely abnormal, and if I attempt to auto-adjust the TV, it flashes different colors on the sides of the screen , and then turns off the convergence settings.
Feb 01, 2010 | Sony Televison & Video
Sony 42in xbr flat screen user's manual How do I turn on the port on the left hand side of the sony xbr flat screen tv?
Let me know exact model of your TV and do you see any label on subject port that you want to turn ON, how it looks like?
Jan 18, 2010 | Televison & Video
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Jun 11, 2009 | Mag Innovision InnoVision XJ 717 Monitor
TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Feb 10, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony Videoscope XBR 53
This is a convergence problem. Look in the back for a couple of large black ICs attached to a heatsnik. These should be marked STKxxx. These are the convergence ICs and either have bad connections or are defective. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. There may be other parts that need to be replaced as well. I'll look up your model to find the other parts to check. The convergence board as an assembly, I believe, is no longer available. The parts that you require are available.
Dan
Sep 18, 2008 | Televison & Video
Sony Videoscope XBR tv
This is usually a convergence problem.. Could you update this with the model number please. That will allow me to give you some specifics about what could be wrong and how to fix it.
Dan
Apr 18, 2008 | Mag Innovision InnoVision XJ 717 Monitor
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
Mag Innovision InnoVision XJ 717 Monitor Logo
97 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
