Question about KitchenAid Blade Coffee Grinder by
KitchenAid coffee grinder
The ground coffee is spraying all over as it comes out rather than dropping into the cup below. Also it seems as if the ground coffee is magnetized in the way it sticks to the glass I put below to catch the grinds. In short it is making a huge mess... I have had the grinder for a few years and it just started doing this recently. We did clean the grinder this past weekend hoping that might help and it didn't. Any thoughts?
Apparently we must be the only two people on the planet with this problem. I have a Breville burr grinder that I received as a gift, and it magnetized the grounds directly out of the box. I am considering opening the casing up and grounding the motor through the plug. I would need to replace the 2-prong plug with a 3-prong plug. The casing is made of plastic and stainless steel, so they wouldn't need to ground the chassis, but if the electric current running through the motor or the burrs (attached to the motor) are the root cause then I would think that grounding the metal chassis of the motor through the plug/outlet should do the trick.
Posted on Mar 14, 2010
Where can I get an Kitchen Aid A-9 burr grinder repaired?
Softly Scrambled: Kitchenaid A9 Grinder Refurbishment.
softlyscrambled.blogspot.com/.../kitchenaid-a9-grinder-refurbishment.ht...
Mar 1, 2014 - This is an original A9 from the days when Kitchenaid was owned by Hobart. ... Yes, it worked and would grind coffee, but the motor seemed to labor and the grinds were ... I am now doing this for mine, but I can not for the life of me get to the bushings. Does ... I don't recall a ball bearing from repairing my A9.
KitchenAid Burr Coffee Mill KCG200 (aka A-9) - Automatic Washers ...
www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?44466
Jan 13, 2013 - 49 posts - ‎12 authors
I'll definitely use that cleaning method if I can't get the grinding mechanism .... I'd try lifting the lower burr assembly out with the aid of two flat ...
Kitchenaid A9 Coffee Grinder - HubPages
hubpages.com > Food and Cooking > Beverages
Sep 20, 2013 - Where can I buy a retro Kitchenaid A9 Coffee Grinder? ... are paying for (is it new in box, has it been used for 20 years, or does it need repair).
KITCHENAID A-9 INSTRUCTIONS MANUAL Pdf Download.
Dec 21, 2015 | Coffee Makers & Espresso Machines
Ground too fine adjust mill comes on about every other cup.
With any coffee grinder (especially those that are used for espresso) the burrs can wear down after a while. It seems like you've used this machine quite a bit and for various different types of coffees. If your machine is still covered by the manufacturer I would suggest contacting them about the problem or call your local specialty coffee shop. They normally have or know of a guy that can fix this rather simple problem for cheap. Happy brewing!
Sep 03, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Ref: Mr. Coffee Burr Mill Hopper: How do I keep the housing of the grinder from filling with large amounts of ground coffee?
You need to clean it out every 3-4 days. I use a brush and pointed knife for the packed grounds. Mine works great now.
Nov 27, 2014 | Mr. Coffee Coffee Makers & Espresso...
Grinder stalls constantly (motor whirring, but no grinding happening) so I shake it to get it grinding again, but the whirring/no grinding happens over and over. I have to shake the think 5 or 6 times to...
As I can see, what happens is that some coffee grains stucks in the way from the upper pot to the grinding wheel. This is not something usual, but possible if coffee grains are too big and are placed across the entry of the mill. Try cleaning more deep with some old toothbrush. Look for a clean and even surface of the duct.
Other cause might be a loosen mill hub/grinding wheel off the motor shaft, which would require dissassemble of the appliance to be repaired.
Dec 10, 2010 | Krups Burr Coffee Grinder
Jura Capresso E8 keeps getting error code 8 over and over. I will clean, remove grounds etc, it will make a few espressos, then back to the error code. I can hear it struggling.
One of the problems that I see with these units is the Grinder setting. Sometimes the grinder is set too fine for Dark and Oily beans. This setting will ( can) clog up the brew screen after less than 10 cups are brewed. Also, running the cleaning tablets through to create a clean starting point may help you. Try turning the grinder to a slightly coarser setting and try that.
Sep 21, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
I am looking for a glass replacement for the receptical for a Kitchenaid top of the line coffee grinder as we dropped the glass receptical.
Try contacting Kitchenaid directly. They have a fairly extensive parts department:
Contact Center Hours:
Monday – Friday 8am – 8pm EST
1-800-541-6390 http://www.shopkitchenaid.com/cc_contactus.asp
Jul 20, 2010 | KitchenAid Pro Line Burr Coffee Mill...
Clogged?
I took the jar off and cleaned/scraped the port out(the square hole that the gounds come out of) then gently "bumped" the top and side of the unit on newspapers to get the accumulation of 40 years of stray grounds out and it runs great now!!
Apr 09, 2008 | KitchenAid A-9 Electric Burr Grinder
Slow
Adjust your grinder to grind coars, when the machine "drip" out the coffee then it is to fine, adjust the grinder two step and then you have to maker 3-4 cup of coffee to make your new tasty coffee;-)
Mar 19, 2008 | Saeco Vienna SuperAutomatica Coffee...
The coffee is comming out very slow (just drops). The display says to ventilate, but this doesn't help.
  • Increase your grinder size.
  • Normally it is 8.
  • Make sure to only change the grinder setting while the grinder is spinning.
  • Change only two numbers at a time then make three cups to see the results.
Saeco Service center and parts warehouse
www.cerinicoffee.com
Nov 26, 2007 | Saeco Incanto Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
287 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
