Question about Metabo W6-115 606111420 4 1/2" Angle Grinder
Disc flies off when grinder stops
We are using a threaded disc, rated at 13,000 rpm. The disc remains in tact and operates correctly until the operation is complete and the trigger is released. At that point the disc comes off the grinder and flies away from the grinder.
  • David Ford
    David Ford May 11, 2010
    Are you using the proper thread size on the wheel? Second are you securing the wheel using the spindle lock. I work on these daily and never have heard of the problem as you described. It might be worth a call to Metabo tech service. Let me know
    Problem Solver:
  • 8 Answers
Yes the above is correct with the question "are the threads the right size." but it can also be because u are not slowing the grinder down before stopping it. if the grinder stopps to soon the disk will stay moving. so the disk will fly off. i had the same problem with a pnuematic grinder. sometimes it is the operaters fault not the tools.
" an object in motion aloways stays stays in motion till an outside force dissrupts it."
Posted on Jan 26, 2009
I changed grinder stone wheels and replaced with buffing wheel... now the grinder will stall when i try to buff things... what went wrong or what did i do and how can i fix it?
Buffing takes a lot of power, maybe a lot more than you expected. Bench grinders come in lots of sizes and power levels. If you have a small, or inexpensive, or fractional hp grinder, it simply isn't up to the task. By the way, rpm is also a big factor. A grinder, especially a smaller one, turns at a pretty high rpm. A given hp rating at a high rpm gives less torque than the same hp rating on a different grinder with a lower rpm. On your grinder you might get away with smaller diameter and/or narrower buffing wheels that you use very lightly. Otherwise, your grinder just isn't going to cut it.
Dec 17, 2012 | Grinders
I just bought a hand grinder from a guy but don't know how to take the disc off . it has a button u push but no nut on the disc
If there isn't an arbor nut holding the blade/disc on the grinder you have a disc with the threaded center built into it. While holding the arbor lock button down you have to turn the disc by hand until it breaks free and spins off. It may be on vary tight as it is a self-tightening thread so the disc won't come off while you use it.
Feb 22, 2012 | Black & Decker Black And Decker 4-1/2"...
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
I own a metabo 9-125 quick but can't don't know how to place the blade
On the silver part on top of the grinder is a button , press this button and hold it down. now turn the blade until it stops moving, this locks the blade, keep holding the button down and turn grinder over ,and turn the nut counter clockwise, and remove it , take old blade off ,put on new one .it should go over the shaft and at the bottom on a "fit" Make sure it is on the "fit". replace the nut and tighten. If you dont get the nut tight enough it will loosen while in use and the disc you are cutting/grinding with will wobble and may even come off causing possible injury .
Jan 29, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
I have a dewalt 4 1/2", 120V angle grinder. I am breaking the thin cutting wheels when I use them very quickly or I pull out the stamped metal ring in the center of the cutoff wheel. The RPM rating...
If you are using these disks you need to apply very light pressure with the angle grinder and ensure you aren't putting any side pressure on the side of the disc.
Also imagine a line at a tangent to the disk. This should be kept at a shallow angle to the work piece to prevent the edge of the metal digging into the cutting disk.
As a rule of thumb you have the correct angle when the sparks are flying at less than 30 degrees back towards you.
Also make sure the retaining flange nut on the angle grinder is the correct way around to grip the disk, sometimes the nut has to be reversed to grip grinding discs.
Nov 24, 2010 | Dewalt Welding Tools
My drop saw runs at 5000 rpm .most 14" discs are only rated to 4400 rpm. Are there 14"discs rated at over 5000rpms
go 2 home depot and buy Norton brand blades a lot of blade suppliers are putting a pic of cutoff saw on the blade itself 2 tell u its 5400 rated home depot and Norton r the cheapest and lasting
Jun 29, 2010 | RTO 20 14" Abrasive Chop Saw Blades Metal...
May i fit bigger disc on my angle grinder,its speeed is 11000 rnd.p minutes,recomended 115 mm disc.i want to fit other big disc.may i do it?will it cause any problems?
there are 3 problems you might face: 1. mechanical - disc shield (or protector) is too small for bigger disc. You can remove the shield (I do not recommend!!!) or buy bigger one (as I've did). 2. RPMs - on each disc you can find maximal speed of ourter part of the disc. It depends on disc diameter and RPMs. In case yo go from 115 to 125 at 11 000 RPM, it should be still OK. But I would not go further. Check how RPMs drops with increasing disc diameter. 3. motor overload. To handle bigger discs motor should produce higher torque. But if you are not pressing on the grinder and you frequently check temperature of grinder, it should work. I have Metabo WE14-125 - 1400W motor 125 mm disc: 1. I've bought new shield from WE14-150 - it fits perfectly 2. My grinder has adjustable RPMs, when I'm using 150 mm disc I'm not going over level 3 (out of 6) to keep RPM in safe range for the disc. 3. Metabo makes also WE14-150 which is almost same as mine, but produces more torque (3,5Nm vs 3,3Nm). But the dofference is very small so I'm not worried. Juraj
May 01, 2010 | Metabo W14 125 Ergo Angle Grinder 5"
I have a brand new Grinder 230mm and now need to change the grinding disc however I cannot get the locking flange off - I have detroyed one spanner, and purchased a stronger one, but still no good. can...
Try turning it the opposite way. Instead of loosening it, you may be tightening it. Reverse threads on these machines are necessary to keep the flange from flying off by itself. Joe
Apr 12, 2010 | Black & Decker 9"/230MM 5,000 Rpm Large...
Motor Speed Question
The RPM rating of the die grinder is the deciding factor in the tool’s usage. A die grinder with a lower RPM is best used for fine grinding and finishing work. Speeds lower than 10,000 RPM are best for this function. A die grinder with an RPM between 10,000 and 20,000 is great for creating rough finishes and minor buffing jobs. If the die grinder will be used to remove metal burrs or to cut metal, it must have an RPM rating of over 20,000 and a no-load speed of at least 30,000 depending on the RPM rating.
Aug 27, 2008 | Viking Die Grinders: 1/4" Heavy Duty Die...
I own the super jolly model grinder
Youmay have have cross threaded the grinder!!! Stop at once! Mazzer grinders have no detents!!! Mazzer grinders are reverse threaded. The way to put on a burr carrier (the thing you screw down) is to (in this case) screw it clockwise until it click down into the threads then screw it counter clockwise. It should feel smooth and silky!
Also the mazzer grinders have 4 sprincs that push up on the burr carrier. If I recall correctly you can push down on a collar sticking up from the center of the adjusting ring to neutralize the pressure of those springs.
If I had cross threaded a grinder I would first be a bit sad. Then I would lube the threads with a touch of mineral oil, bite the bulet and back the burr carrier off. If I dinged up the threads on the carrier I would clean them up with a metric thread file, If I dinged up the threads on the reciever I would have a machien shop clean them up with a metric thread rake. Try not to remove too much metal, though with the springs stabilizing the burr carrier agains the adjusting collar a mazzer cna take more abuse of this type than most
Nov 15, 2007 | Mazzer Coffee-grinder SUPER JOLLY Electric
Metabo W6-115 606111420 4 1/2" Angle Grinder Logo
146 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
Are you a Metabo Saw Expert? Answer questions, earn points and help others
