Question about Samsung DLP HL-P5663W 56" TV
Samsung HLS5687WX/XAA color wheel not spinning. It is "twitching" and acting like it wants to spin, but will not. Moves when I do it by hand, but has a slight squeaking sound.
    Sergeant:
  • 214 Answers
If I were you I would grab 1 of these needle oilers. Put a tiny bit where it spins as it may now be binding and not able to move. Be careful not to get onto any electrical components or the wheel itself.
Posted on Nov 28, 2012
3 Suggested Answers
SOURCE: Samsung hln 61 make loud humming
yes this is a very common issue with Samsung DLp's, and it will get louder and louder until TV will not turn ON anymore. You can replace it yourself is very simple, here is kind of a guide for that http://guides.fixyourdlp.com/samsung/bp96-01579a.php and http://guides.fixyourdlp.com/samsung/bp96-01854a.php
Posted on Jun 25, 2009
  • 32 Answers
SOURCE: I have no color on my samsung hln5065wx/xaa DLP
If it is just no color but you still have a picture it should be your digital board. This is the board that mounts behind the light engine and should be encased in a shilver colored metal sheild
Posted on Aug 13, 2009
Samsung HLS5687.Replaced lamp,turned on TV the light goes on turns off. The projector boards continues to beep then tv powers off. Color wheel does spin. Not sure what the beeping is.
Did you check the ballast for the lamp? It provides the high voltage/energy to excite the lamp (no filament) into operation. If it does not work properly neither will the bulb.
Great set - I have the 5685.
Mar 06, 2016 | Samsung HLS5687WX/XAA
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
We have a Samsung #HLN5065WX/XAA that has started making a very strange noise and flashing "Check fan no. 2". The colors are also off. What can I do to fix this?
The tv is making loud noises like humming or motor noises and tv have strange colors flashes or black and white backgrond flashes.The tv Colors wheel it is dying and not spinning the right speed of it RMP speed any more.The tv colors wheel must have be replaced to solved this problems.Have no mechanicals skills hire a tv tech. to change the tv colors wheel because u have to take out alot of mechanical parts out before u can come to the tv colors wheel itself to replace it.
Aug 20, 2011 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP hlp5063wx/xaa - Cycles through the warm up 2 times but does not turn on, then 3 lights flash on the front (2 green, 1 red) Bulb is new and looks good, fans seem to be spinning freely. Any...
If your having the "3 light" problem it could be an indication of a bad lamp however if there is a buzzing or a grinding sound it could be one of two moving parts. The color wheel or the cooling fan. I would go the cheaper route and replace the color wheel first since you say the fan is spinning. The thing is the lamp will not turn on if there is a problem with one of the other two parts. The motor on the cooling fan is too small for such a big fan so I would definately try it next. It's a big problem with the DLP tvs. good luck!
Feb 14, 2011 | Samsung Televison & Video
Samsung HLT5076SX XAA turned itself off. Two
If you do not hear the color wheel start to spin inside of light engine this may have failed also check to make sure fans are working and safety switch is making contact
Mar 05, 2010 | Samsung HL-T5076S 50 in. TV
TV SAmsung, the picture is bad after color wheel changed
Hi,it's possible they gave you a different color wheel,there's a silver version and a gold version they spin at different speed,so mostlikely they gace you the wrong version check what this website says about the 2 versions : http://www.discount-merchant.com/product-p/samsung_bp96-00674a_colorwheel.htm God bless you ask for a refund.
Oct 06, 2009 | Samsung Televison & Video
My samsung DLP hls5687wx xaa shuts off by itself. How do I fix it?
The lamp ballast or Color wheel might be the problem. We have experienced both issues with the tv shutting down. Also check the hours on your lamp as it might be getting old.
Jul 07, 2009 | Samsung 56" Slim-Depth LED DLP HDTV
I need help with my DLP TV
If you have verified the votages are there at the color wheel and its not spinning the color wheel is most likely defective. the sound you hear when spinning by hand is most likely the bearing but that shouldnt stop it from spinning. but as i said if the supply voltage is present but it still wont spin. the color wheel must be defective.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
My DLP TV wont turn on.
As part of the power up sequence on the Samsung HLP-4336W the lamp isn't turned until timing pulses are detected from the color wheel. The color wheel motor is powered through the flat brown four conductor ribbon cable and the timing pulses are detected over the the three conductor ribbon table.
TV will not turn on, Have three blinking lights, lamp won't turn on, color wheel isnt spinning.
the color wheel wil need to be replaced soon if it is doing that. it could be then DMD board as will.
Samsung DLP HL-P5663W 56" TV Logo
209 people viewed this question
Jerry Greenberg
Jerry Greenberg
