Question about Husqvarna Garden
395xp Chainsaw won't start. - Husqvarna Garden
5 Suggested Answers
jisake1
  • 19 Answers
SOURCE: My Ryobi 4545 Chainsaw started but would not tick
Check your anti kick back bar across the top. If you bumped it forward will not start.
Posted on Aug 27, 2011
hunter19_46m
  • 7482 Answers
SOURCE: chainsaw won't/ starting diffcultiy .would
Hi jeffery webb... Make sure you are getting spark at the spark plug, to do this: Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug. You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark. If you are getting a nice blue spark then skip A below and go to B. A...If you do not get a nice blue spark then you may need to replace the electronic module. Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting. B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area. Then follow the procedure below: ********************************************************************** Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible. Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel. Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT. Note:Before you disassemble the carburetor: Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor. Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces. That way you will know which way it goes back together when you reassemble it. Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor. Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank. Check you fuel line condition after a while they will degrade and need replacement. Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws . When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a picture for later reference. Normally the big line will be the line the fuel filter is connected to inside of the tank. The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb. Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking. If the chainsaw is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank. The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc. When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages. Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable. Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages. Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages. Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from. When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws. But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position. Be sure to mark the turns down on a piece of paper. That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started. Note: The little spring inside of the carburetor goes under the float arm. That is where your fuel inlet needle/float valve is located...on the arm at the end. Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation. The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position. Once you have your carburetor cleaned/rebuilt that should solve your problem. Please take time to rate me thumbs up
Posted on Sep 29, 2011
SOURCE: Chainsaw won't start. Replaced carburetor, fuel lines, fuel filter, ignition module, spark plug. Using new gas and oil. Has good spark but won't pop.
try priming it mite work lol
Posted on Mar 29, 2012
  • 2239 Answers
SOURCE: 395XP chainsaw
The 395 has an electronic ignition, as this unit works off speed of rotation you need to make sure you are cranking the engine fast enough to check for a spark, to eliminate the switch and wire, dissconnect the wire from the unit itself, now try for a spark, if still no spark with a new plug, you will have to replace the unit
Posted on May 08, 2012
How to remove chainsaw muffler
If this is the Husqvarna 440, there are two allen headed screws sunken down inside the holes in the front of the muffler, its either a 5mm or 6mm long arm allen key required.
Jun 16, 2013 | Husqvarna Chainsaw 440E-18
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
Chainsaw won't stay running
You must have dirt in one or more of the carb jets. Remove the carb and clean it with carb cleaner spray and compressed air (compressed air is a must).
May 10, 2012 | Echo 30.1CC Chainsaw With a 14 In.bar and...
395XP chainsaw
May 08, 2012 | Husqvarna 395xp Gas Petrol Chain Saw Husky...
I am looking to purchase a husqvarna 395xp chainsaw but not sure how old it is. The numbers on the side are 965 90 22-00 over 01 1900504. thanks
Hi Charles,
Your saw was made in 2001. 1st 2 numbers of the serial number. That's a big saw though and seems to be pretty reliable. I put a link for a review here for you. Tanks Dane
http://www.backyardboss.com/mfg_Husqvarna/395xp.aspx
Dec 13, 2010 | Husqvarna Garden
I recently purchased a secondhand 395XP husqvarna and need manual
you can try searspartsdirect.com or outdoordistributors.com there pretty reasonable
May 18, 2009 | Heavy Machinery
Garden Logo
160 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
