Question about Bissell SpotBot Robotic Wet/Dry Vacuum
No voltage to pump motor when the surface stain button is pressed, the unit is on and the green light for the pump is lit and stays lit.
  • Official Brand Answer
  • 315 Answers
You may want to contact one of BISSELL's Authorized Service Centers for assistance. Here's a link to locating one.
http://www.bissell.com/service-centers/?cid=ccsocial
Posted on Dec 04, 2012
Brush not working, green light not lit. have taken apart and put back together but still not working.
Hi Carol, Many models have a reset button (breaker) on them to protect the motor that turns brush. Look for one of these on yours and reset it. Should be on the outside of the unit.
This could also be a missing or worn belt. If you forgot to look for this when you had it apart, open it up again and make sure there is a rubber belt running between the motor and the pulley on the brush. If it's there, try turning the brush while holding one side of the belt with your fingers, to see if the brush pulley slips easy under the belt. If is does, you need a new belt. Make sure it's not plugged in... : )
Hope this help....
Mar 01, 2016 | Vacuums
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Start button doesn't work
test the switch.
see the diagram below. God bless you
if the switch is o.k 2) test for continuity the wires 3) Test the motor input voltage motor. 4) Test the power cord for break or loose wires with VOM
May 24, 2012 | iRobot Roomba 530 Robotic Vacuum
My simer ace in the hole a5000 will not charge my 2.5 year old battery. The battery voltage reads 10.75 volts. I replaced the twelve volt charger and it originaly lit the yellow charging light , but it no...
I does sound like a controller issue. Try testing the charging output (be careful, who knows what the voltage may be coming out) I would say it is the battery but the yellow light thing has me thinking you are right. That thing has been sitting there maintaining the battery for 17 years, it is probably tired. The other bad news is if your battery has been sitting at that low volta.ge it may have a greatly reduced capacity now. Hope this helps some. .
Jun 09, 2011 | Vacuums
My iRobot scooba won't turn on after a full charge
Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
Jul 26, 2009 | iRobot 5800 Scooba Vacuum
Low tire light stays lit.
If there is a red reset button in the fuse box, press & hold till your air pressure light flashes off....do this with the key on, engine off
Jan 09, 2009 | NexxTech 611-8212 Handheld Wet/Dry Vacuum
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
100 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
