Question about IBM LENOVO POWER SUPPLY AS-400 74G9796 Power Supply
Replace 74g9796 power supply - IBM LENOVO POWER SUPPLY AS-400 74G9796 Power Supply
Why did my pc power supply shorts..everytime it replaces a fuse its short,,do i have to replace it a new power supply?
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Jan 27, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
NEED A NEW UNIT OF POWER SUPPLY ATX-400W REV T1
Jan 25, 2011 | HP ATX-400W, ATX-400W Rev. T1, HP P/N:...
At start up, no signal on monitor, computer shuts down.
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacement from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Nov 09, 2010 | HP Pavilion Replacement 200w Micro ATX PS3...
Have the HP-D3057F3H power supply - plug it in an the green light is flashing quickly - PC wont turn on - Is the power supply buggered or is it something else
Oct 27, 2010 | HP Compaq Power Supply
Power supply light flashing green ,,, tried unplugging mother board still flashes green is it the power supply or the mother board?
Aug 14, 2010 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Power Supply Replacement
It never hurts to have a larger power supply, yes it have use 100watts more in a hour. But you should have better reliability with the 450W.
Mark
Apr 05, 2009 | Computers & Internet
No pwr supply light on Pavillion desktop pc
Dec 20, 2008 | HP and Compaq Pavilion Replacement 200w...
Power supply replacment
You should be able to replace the power supply. It is usually held in place by 4-6 screws. Unplug the cables on the motherboard and drives. Reconnect the new ones and away you go. A generic supply will be fine if it is of the correct physical size. Bring the old one with you when you go to get the new one.
Dan
Mar 18, 2008 | HP Pavilion A520n (DW233A#ABA) PC Desktop
Computers & Internet Logo
27 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
