I need to replace the fan on the Black & Decker BV2500 Leaf Blower/Vac. have the new fan coming but need to know how to get old on off.
SOURCE: My black and decker leafhog blower/vac smells like something is burning
Black and Decker has issued a recall notice for Type 1 BV4000 because "a loose connection between the unit and an extension cord can create heat, posing a possible fire hazard" Says to STOP USING and call 1-866-853-2138 to arrange for free repair. (Found info by Googling "Black and Decker Leafhog", navigate to Black and Decker website and click "Important Safety Recalls" button at bottom of page.)
SOURCE: User manual for Black & Decker Yard Cleaner 82410
Hi there
You can get a user manual and a parts breakdown on the link below
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=19132&typeId=1668&documentId=1612
Hope this help
SOURCE: black and decker leaf hog on off switch schematic
Take out all the screws. Gently remove half of the case. Put a shim in behind the plastic pivot that rocks the switch. I rolled up a 1/2" by 3" piede of duct tape and jammed into the back of the oval socket for the rocker. This pushes the rocker against the switch hard enough so that it rocks the switch properly. Snap the case into place and test the switch before you put the screws back in to make sure it is now working properly.
SOURCE: Where can I get a new replacement bag for my Black
http://www.blackanddecker.com/CustomerCenter/parts.aspx
this link should help you with anything you need.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: Black & decker blower/vac runs slow, problem started all at once
I've had the same problem at work with troybuilt leafblowers. It eventually turns off as you use it yeah? It could be a little flooded and the engine isn't getting enought air. Find out where the carbeurator is, take it off, dump out the excess fuel, and spray out with WD-40 or carb and choke cleaner, make sure there's not a lot of excess fluid left and then try it. I've seen and old guy try it on a lawnmover I had that kept doing the same thing, and it fixed it just like "that".
