1993 Goodman gas furnace keeps blowing fuse when first turned on
I connected the thermostat on a short piece of wire to see if a screw in the wall was shorting to cause the fuse to blow immediately and it still blew. Blower works fine without blowing the fuse.
  • gmabell
    gmabell Nov 30, 2012
    I was able to purchase a very inexpensive thermostat and tried it, in case mine had n internal short. It worked!!!!! I now have a warm house! Thank you!
    Genius:
  • 1,033 Answers
You can take each thermostat wire off the control board and use a ohm meter and test to ground, should not have any resistance. Another way is turn off power take each wire off the board, then place one wire at back on the control board terminals ome at a time, untill the one you get to the one that blows the fuse. If the wires check out good sometimes the thermostat itself can have a internal short and cause the fuse to blow.
Posted on Nov 27, 2012
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
Goodman furnace GMT115-5B Turn fan to on on
Bypass the tstat first but that's where I'd be leaning.
Aug 14, 2017 | Goodman GMS90703BXA Heater
Fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
Jul 16, 2010 | Goodman GMS90703BXA Heater
My Goodman furnace wont light.
Open up the unit to get to the control board. Make a short jumper wire and disconnect the wires going to R and W terminals on the board. Connect the jumper to R and W. Depress the door safety switch. The circuit board should indicate a call for heat and the furnace should start. If it doesn't, look for a fuse that may have blown either on the circuit board or in the wiring. If the unit started by jumping the W and R but does not when you reconnect the thermostat, you either have a bad thermostat or a bad thermostat wire.
Dec 02, 2009 | Goodman GMS90703BXA Heater
I am tying to install an RTH6400 5 in 1 thermostat but the colors of wires i have on my wall are RED, GREEN, BLUE AND BLACK, where as the book has RED , YELLOW,WHITE AND BLUE. please which do i connect to...
You need to open up the panel at your furnace(air handler) and find the terminal strip and see what your existing thermostat wires are connected to. Normally your red wire connects to the R terminal(24 volts), the yellow wire to the Y1 terminal(cooling), the white wire to the W1 terminal(heating), the green wire to the G terminal(indoor fan). You can use whatever color of wire you have existing, just make sure that the R,W1,Y1,and G wires at the furnace match the R,W1,Y1, and G terminal screws at the thermostat. Also make sure the power to the furnace(air handler) is turned off before you make any wiring connections at the thermostat or furnace.This is very important! If you don't and you short any wires to ground(especially the R wire) you will possibly ruin the system step down transformer or blow the low voltage fuse.
Nov 10, 2009 | Honeywell Electronic Programmable...
Goodman GMP75... keeps blowing fuses only in A/C mode. Only when I connect yellow wire from thermostat to line going to condenser contactor (24V side).
Are you talking about the small 3 or 5 amp fuse in the furnace? If you are then the control voltage circuit to the condenser is shorted, Maybe dogs or rodents chewing it or the insulation is cut by a sharp piece of metal. Sometimes the contactor will go bad and cause the small fuse in furnace to blow. Look for the simple things first, like control wires shorted. Make sure the yellow wire from the thermostat goes to the outside unit and not to the common.
Jun 30, 2009 | Goodman GMS90703BXA Heater
I have a goodman furnace and ac unit heat and fan work but soon as i flip the ac on it blows the 5amp fuse at the furnace
their is a control short some place check the control wiring . dog or rodents chewing threw it or shorted controls or thermostat id get service. Tom
Jun 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Williams wall furnace, top vent.
I've replaced a Williams wall gas heater non-electric. The thermostat is connected right and mounted on the wall. But, there's a thick black copper wire on the side of the furnace tagged thermostat. I don't know what to do with it? Where do you connect this wire? When it touches the top screw of the three screws running vertically(where the other wires are connected). The burner lights up and stays on, even if you play with the wall thermostat. Touching the other two screws doesn't do anything. Now, the manual talks about connecting it to the venting wires? Extra wires coming from the top or maybe somewhere else in the wall? I've left it connected to the first screw, ran the heater. But, it never turns off? Any suggestions? Thanks
Dec 13, 2007 | Heating & Cooling
Open Questions:
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
