Question about KitchenAid Dryers
Installing heating element kitchenaid keys850jq0
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 28, 2012
My kitchenaid electric dryer not heating
Kitchenaid dryers have real weak heating elements, I would test that first, if you have an ohm meter look for small resistance, an open would mean the heating element is bad.
Jun 20, 2012 | KitchenAid Dryers
Kitchenaid dishwasher is not cleaning the dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 30, 2011 | KitchenAid Dishwashers
Dishwasher will not go into Dry cycle. It was given to me and perhaps I did not install it properly.
Check your heating element..
How to Replace the Dishwasher Heating Element
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 13, 2010 | KitchenAid KUDI24SE Built-in Dishwasher
I need to replace the heating element and electronic control board on my Kitchenaid KUDS01DL Dishwasher. I have the parts. I have been able to find directions on how to replace the heating element, but...
Go to www.repairclinic.com and enter KUDS01DL. With luck, you will be presented with a list of common replacement parts and may be able to vie a generic KitchenAid video showing disassembly and replacement parts installation.
Aug 29, 2017 | KitchenAid 24 in. KUDS01DLSS Built-in...
I have a kitchenaid dishwasher that is not cleaning the top rack of dishes, but the bottom rack gets a great cleaning. What do I do?
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
oi57
Aug 04, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
They just installed a kitchenaid 36 inch KDRP467K
Hello- 'They' should have re-checked bus block connections for cord. Element won't work with one leg. If connections look good, check element connections and then power connection for element at board. If it still doesn't work, check resistance of element. Should be around 13ohms. This is the troubleshoot sequence for solution to your problem, but should be under warranty for first year. A piece of advice- avoid the 'self-clean' function. This feature is called 'self-destruct' by techs. Please acknowledge this post if helpful. Have more info if needed. Thanks-  Ed
Mar 23, 2010 | KitchenAid Kitchen Ranges
One of the burners on my kitchenaid cooktop will not heat up. What do you think the problem is? Is this something that can be easily repaired?
If it is not a glass top stove, with the power OFF, and cold, pull out a working element of the same diameter and install it where the non-working element was. Try it now. If it works, replace the heating element. If it does not, check for voltage at the element connector. CAREFULLY. Worst case is that the switch requires replacing.
Dec 17, 2009 | KitchenAid 32 in. KECD805 Electric Cooktop
KUDP01IL Dishwasher heating element
element on allthe time sounds like a direct short of the wire leading to it, trace back the wire , it will lead directly to control board behind front panel. there should be a tech sheet behind the lower kick panel complete with wire diagram
Feb 27, 2008 | KitchenAid 24 in. KUDP01IL Stainless Steel...
HEATING ELEMENT
hi follow the manual: http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8574093.pdf if it dosent work then as you mentioned the heating unit is bad you can replace it by yourself by buying it and insalling it its easy as installing a lamp but you can call for help (number in the manual) good luck
Mar 21, 2006 | KitchenAid 24 in. KUDI01IL - Multiple...
Dryers Logo
47 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
