Question about Philips CD5353S05 Trio 1Line Cordless Expansion Handset
My philips n778 keeps searching
My phone wants to keep searching and I cannot use it
HOW CAN I TURN ON THE SYSTEM KEEP ON SAYING BOOTIING PLEASE WAIT
Most likely system is searching for missing or defective component/connection.
May 23, 2014 | Philips WACS700 Shelf System
Telephone socket fine (tested) but phone keeps searching & saying "out of area""
if you've made sure that the jack is good,by plugging in a known working phone and ensuring that it works, try swapping the line cord between the 2 phones, if that doesn't do it, make sure the line cord is plugged into the correct jack on the back of the cordless phone, there often are 2 of them. good luck.
Dec 28, 2013 | Philips Lands Phones
Describe your HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook Problem Have set up Skype on my laptop, but it keeps...
I understand your problem with the Webcam.
It appears the driver may be missing or corrupted.
Click on "Control Panel", then "DeviceManager", you will then see a list on all the devices on your computer. Look for the webcam, it may be listed with one of the listed items such as USB, double click to make sure it listed. When you find it, uninstall it and then reboot your computer.
After bootup, the webcam will be detected and Vista will go out and search for drivers.
I am also suppling a link below to HP, for your model laptop, for drivers that may be needed.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3224052#N778
Good Luck
Aug 27, 2011 | HP Pavilion dv6000z Notebook
After power cut the phone will not connect,it just keeps reading searching in the screen no dialing tone,the line appears ok as a normal plug in phone works ok can you help many thanks. I cannot find the...
I think if you switch off by holding down the 'exit' key for about 10 sec, then switch on again (same key) it might recover. Mine did, but seems to need the process repeating from time to time. When switched on again it still has to search for about 5 minutes.
Jan 07, 2010 | Vtech Digital Cordless Telephone VT-2568
Phillips CD130 Cordless Phone
Harry, take the batteries out the back for 2 mins.When you put them back it will refresh the phone and should be ok
Steve
Aug 13, 2008 | Uniden Cordless Phone
Philips cordless phone CD245 Handsets will not find base station - they keep searching all the time.
Simil problem. Also then clocking in DSP not oscilation. then facking mather of Philips
Jun 22, 2008 | Lands Phones
Phone says searching
The battery may be weak. Or it is too far from the base. Try exchanging the two. take the handset near the base and see if it will link.
Jan 28, 2008 | Uniden Cordless Phone
Philips CD5353S05 Trio 1Line Cordless Expansion Handset Logo
60 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
