Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia kdl-40m-4000 - turns off - timer light flashes - timer is turned off - Go to menu and it says timer off - but the timer doesnt seem to know this
SOURCE: How to do a complete factory reset of a Sony Bravia KDL-32P3000
Just talked with Sony Support today.
It seems that Sony in Denmark had sent out new software updates (over DVB-T) but also some wrong TV's got updated as well. This caused my DVB-T tuner to not function anymore so I wanted to try a factory reset and it fixed my problem.
So I was instructed on how to do this. I have a Sony Bravia KDL-32P3000 (which should be similar to the U3000 and S3000 as well).
This is how to do a factory reset of your Sony Bravia KDL-32 P/U/S-3000 TV.
PLEASE BE VERY CAREFUL WITH THE SERVICE MENU, YOU CAN EASILY CAUSE YOUR TV TO MAL-FUNCTION!!!! IF YOU FOLLOW THIS GUIDE IT IS AT YOUR OWN RISK!!!
Set your TV in standy (use the green power butten on your remote), RED standby LED is ON on your TV.
Now press these buttons in this order on your remote (pointing to the TV).
i+
5
VOL UP (+)
GREEN POWER button
NOW BE CAREFUL! Dont press any keys just for the fun of it!!! IT MAY DESTROY YOUR TV.
You should now be in the service menu. It will show up as some green letter/numbers spread over the screen (mine are a bit hard to see/a bit faded). In the upper right corner you should have 2 letters TT (two t's).
Now carefully press key 0 and then key 8 on your remote (they should be shown on the screen after the two TT).
Now wait a little while (more than 10 seconds) and your TV should reset with factory settings, just as if you had just brought it home from the TV store.
Best wishes,
Mads
Posted on May 15, 2009
prawinmv22
  • 106 Answers
SOURCE: light flashing 13 times on sony bravia KDL-46x3100
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Posted on Jun 16, 2009
cene765
  • 787 Answers
SOURCE: Sony Bravia KDL-52XBR9
There is a error in TV.Count how many times blinking the red light.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Posted on Nov 16, 2009
Testimonial: "I also bought the Sony KDL-52xbr9 mine did the same thing with six blinks. I sent it back to to store. "
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 50 Answers
SOURCE: slow moving image sony bravia KDL32M3000
Hello darwin_gabou, My names Dave! You have a bad A/V input board.
Part #: A-1376-788-A
Link to part: http://www.shopjimmy.com/catalog/product/view/id/169673/s/sony-a-1376-788-a-bm-board-for-kdl-32m3000/
Please feel free to contact me if you have any question. I'll be more then happy to answer any questions you may have!
Dave
503-432-9904
Premium TV Tech
www.pleasefixitdave.com
pleasefixitdave@yahoo.com
Posted on Apr 01, 2010
I have a Sony KDL-52S5100 tv. Is there any way to have it turn on using a timer? Internal or external.
Off timer function is there with this TV menu. Refer its user manual for details. No external timer should be used. Electro help
Dec 02, 2014 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Sony bravia KDL-37V5810 flashing red light 10 times and doesnt turn on.
10 times flash denotes a T'Con fault. There are some other reasons too for this. If you wish to get more details about blinking codes to Sony TVs, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 06, 2013 | Sony BRAVIA XBR Series KDL-40XBR9 40-Inch...
My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Oct 09, 2009 | Sony Bravia KDL-26S3000 Television
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Sony Bravia has sound but no picture
hi have you check the sleep timer on the tv cause it might be on and you need to turn it off
Jan 12, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
6 flashing lights
Similar problem with my Sony. I unplugged for 36 hours and it seemed to solve the problem.
Dec 28, 2008 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
Nov 03, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
191 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
