Question about Sony Handycam CCD-TR3300 Hi-8 Analog Camcorder
Tape carrage problem
With tape in carrage, the tape won't go down. take the tape out of carrage and carrage goes down fine.
Where do I start?
Milt
  • 5 more comments
  • mschroe919 Jan 10, 2009
    Thanks for the reply.
    no dew and no humidity, no error signs?
    no error signs and yes the head turns.
    Thanks
    Milt
    Thanks
    Milt
  • mschroe919 Jan 11, 2009
    Thanks welcomejee, you were right I took it apart and there must have been a obstruction, cause when I put it back together it works
    thanks again
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Then there is no reason, not to load cassette in camera mechanism.
    Please check some thing obstructing the tape to be loaded as it seems some mechanical issue.
    Check, does video head rotate when you close cassette compartment with tape-in.
    Check camera lcd for any error signs like Dew / humidity ?
  • 10,594 Answers
Can I expect fixya rating with 4 blue diamonds now?
Posted on Jan 11, 2009
This is milt with the ignition fuse problem. the truck is a 1989 chevy k2500 4wd
good morning milt,so your saying its the ignition fuse that keeps blowing in the fuse block inside truck,is that right,and does it blow imediately or take sometime.
Jan 10, 2015 | Cars & Trucks
Chevy Malibu 2003 cranks but won't start! I know
You might have a defective fuel tank pressure sensor!
May 05, 2012 | 2003 Chevrolet Malibu
Have an RCA VR618HF VCR. Have cleaned the head and roller. Have problem with inserting tape, unit shut after about 10 sec. and eats tape. Took top off to watch. Tape goes in, two arms strect the tape...
Before you insert the cartage. Look to see if the carriage is all the way back. If it not. The unit is out of sync. A gear has slipped a tooth some where. I don't about this particular model, some vcrs have a belt drive, Take the bottom off and see if there is a belt. It could be slipping or broke.
Oct 28, 2009 | RCA VR618HF VHS VCR
The tape carrage wont load the tapes but it will go into the load position without.
I have a sony cam myself. If the cam is empty, you open the outer door(swings out), and the load/unload mechanism rises up and pops open allowing tape insertion. When a cassette is placed into the mechanism, you press where it says "push" and then the drive pulls the tape down and into the unit. Then the outer door is closed and you're ready to tape. IF YOU PUSH DOWN ON THE TAPE WHILE IT'S BEING PULLED INTO THE UNIT IT WILL STRIP GEARS INSIDE. The gears are made of nylon to prevent serious damage to motors and other circuitry. This transport setup cannot be forced at all. If any type of mis-alignment occurs, the mechanism is supposed to stop and back up--allowing the problem to be corrected. If it is damaged, the cam must be repaired. There is critical timing involved in replacing the tape carriage.---Rick
Sep 10, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
The ink carrage keeps slamming the the left over and over.
Clean the semi clear strip that runs from right to left and goes through the carriage. This tells the carriage position by a very fine amount of lines. If cleaning the strip does not work then attempt to clean the reader unit on the carriage. Just use a qtip/cotton bud slightly moistened in metholated spirits or light cleaner like windex. If your printer does'nt have a strip like I explain then it's likely a switch at the end of the carriage runner.
Hope this helps
May 05, 2009 | HP Officejet 5610 All-In-One InkJet...
HP designjet 430, the data and media light come on at power up
The sad part unfortunatly is that the sensor on the carrage is below minimum specification. The only solution is to change the carrage as a unit P/N C4713-60039 and its going to be expensive. Normally the carrage belt would be replaced at the same time.
Dave
Feb 21, 2009 | HP DesignJet 450c InkJet Printer
Tape jammed
sorry guys/gals problem was mechanical the riser carrage had jammed so used a big srew driver and mallet to get the tape out unscathed so problem solved thanks anyway.
Aug 17, 2008 | Canon Video Cameras
Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
Sony Handycam CCD-TR3300 Hi-8 Analog Camcorder Logo
49 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
