Question about Maytag MDB5601AWW Energy Star Built-in Dishwasher - White
Maytag dishwasher door latch stuck
Door is closed and latch is stuck wont open
3 Suggested Answers
SOURCE: Dishwasher latch handle is stuck in closed
I had the same problem and with some pushing and pulling I got the door open again.
TURN OFF THE BREAKER....
Next take all the screws out of the door panel to access the door latch assembly. You will see the handle has plastic tabs that hold it in place which are broken. Order a new assembly and install it.
My problem was getting the wiring harness off of the switches they are clipped on very tightly so I just kept the old ones connected and put them on the new assembly.
Good luck
O
Posted on Aug 22, 2009
  • 28 Answers
SOURCE: broken maytag door latch assembly
unscrew from bottom
Posted on Nov 17, 2008
Drivers door wont catch and can shut or lock car.. all others are fine. Any ideas?
Car Door Won't Close or Stay Shut - JamesMaurer.com
https://www.jamesmaurer.com/car-door-wont-close-or-stay-shut.asp
If your car door won't close or stay shut then this quick free fix is just for you! ... It's a great day when you can prove to your child your not as old as they think you are :) .....It's pouring outside and my rear passenger door latch messed up. .... two doors and I couldn't shut them.. was worried I would have to catch the bus until we ...
Repairing a stuck latch on a car door - YouTube
? 4:24
https://www.youtube.com/watch?v=tQYWOK1q_iQ
Dec 22, 2012 - Uploaded by backyardmech
Fixing a stuck latch on a car door. Video shows that the door won't close, how to release the latch, the ...
Ford recalling 390,000 cars over door latch woes - Autoblog
Jan 16, 2016 | Cars & Trucks
My GE dishwasher door is stuck closed
Have you tried wiggling it side to side? The diswasher may not be secured properly and will vibrate while running. If the counter opening is relatively small it can be hard to open the door if the dishwasher is off center.
Mar 15, 2015 | GE Dishwashers
Trunk latch is stuck, door will not close toyota matrix 2003
try putting a screwdriver in latch while opening with the handle you might have hit it and closed latch when door was open
Feb 18, 2015 | 2003 Toyota Matrix
Open a crew cab stuck door on F-150 pickup truck
check the opposite side door to see if you can take off the inside door panel with the door closed. If you can, remove the door panel and find the cable/mechanism to the latch, move it to open the door and fix/replace.
Sep 27, 2014 | Cars & Trucks
My 91 chevy truck is stuck open
SOUNDS LIKE LATCH WAS IN CLOSED POSITION WHEN DOOR WAS SHUT I'VE HAD IT HAPPEN A FEW TIMES PUT A SCREWDRIVER IN THE LATCH OPENING AND PRY WHILE PULLING INSIDE HANDLE...IT MAKE TAKE A TIME OR TWO
Oct 11, 2012 | Chevrolet Cars & Trucks
Samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Jun 22, 2012 | Samsung 24"" Dishwasher
Vw 2.0tdi the passenger door wont open from outside and wont always close??
Take off the door panel and check to see if the linkakge from the outer handle to the latch has become disconnected and for the closing problem lube the latch well more than likely its not opening fully when you pull the door open so when you go to close it it pushes the latch closed before the actual bar its suppose to latch to enters the latch
Dec 31, 2011 | Cars & Trucks
The door latch on my maytag dishwasher is stuck in the closed position even though the door is open.
I don't have a solution but I have the same problem. Did you ever get it unstuck? And how??
Jul 07, 2011 | Dishwashers
Door latch wont latch and keep door shut
Sometimes these get stuck in the closed position...try pulling up on the inside door release before trying to close again...this re-aligns the catch to work properly...if needed then compare the door latch to the same door on the other side to adjust to open/close as needed...Hope this helps.
Feb 28, 2011 | 1994 Oldsmobile Cutlass Ciera
Its cold and the door was frozen stuck. But after unlocking it, I pried it open and when I got in the drivers seat to close the door. The latch is stuck in the down position and the door wont close or...
spray the latch catch with oil or silicone to loosen the latch mechanism than stick something [a screwdriver/ pen ] that u can use to push the catch upward to open push on catch while lifting handle if catch falls back either latch spring still frozen or latch spring broken and needs replacement
Jan 11, 2011 | GMC Yukon XL Cars & Trucks
Maytag MDB5601AWW Energy Star Built-in Dishwasher - White Logo
159 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
