Question about Zebra QL420 Thermal Printer
Zebra QL420 plus printer printing blank labels
SOURCE: ZEBRA 105SL : PRINTING PROBLEM
Thanks your the solution. This helped me a lot.
Greetings
Thomas
Posted on May 05, 2008
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
Posted on Jun 10, 2008
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
  • 32 Answers
SOURCE: Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Posted on Oct 27, 2009
  • 31 Answers
SOURCE: Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
Posted on Jan 31, 2010
Printing blank label
You need to give more info.
Are you using labelling software?
Dec 06, 2015 | Zebra Z6M Plus Thermal Label Printer
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
LABELS FOR ZM400
The labels for the ZM400 and the QL420 are not interchangeable.
Aug 10, 2010 | Zebra QL 420 Plus Thermal Label Printer
Loftware labels printing off staggered.
Most reasons for this is a slight adjustment problem with page length. You can recalibrate the printer via the menu system, doing it this way will adjust the sensors with new settings
Mar 11, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Zebra QL420 portable printer label gets misaligned frequently
There are two things to consider here: 1) Is the printer set to the correct media handling setting? Look in the manual for the terms BAR-SENSE and GAP-SENSE and make sure that you have sent the correct command to the printer. 2) There is a TOF or Top of Form setting that you can send to the printer to align the perforation of the labels with the tear bar. Look for the syntax in the manual, which is free for download at zebra.com, and make sure that your perfs line up with your tear bar.
Oct 19, 2009 | Zebra QL420 Thermal Printer
ZQL420+ is printeing an extra blank label with each good label.
Check if you have " send Form Feed after each file" is enabled (or yes) in your print queue
Nov 20, 2008 | Zebra QL420 Thermal Printer
Zebra QL420  Thermal Printer Logo
70 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
