Question about Garden
What is the spark plug used for 22 Inch craftsman 6.0 Lawn Mower?
ccrozier_agr
  • 36 Answers
SOURCE: broken starter cord lawn mower #944.368300/craftsman
Please note ! patients is required with this one !
Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
Remove old cord.
With your new cord lace it through the recoil spool centre hole with a knott on the end.
now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
But hold the spool firmly untill the cord has a good knott on the end of it.
(Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
Posted on Nov 29, 2008
SOURCE: I need the owners manual for this lawn mower Craftsman 917.377220 6.75 HP
Here a website that gives a list of Craftman Lawn Mowers and it owner manuals. Hope it help, its were I found my manual.
http://www.craftsmanlawn.com/Walk-Behind-Mowers/
Posted on Jun 22, 2009
centralvalle
  • 386 Answers
SOURCE: what is the spark plug gap for a 6.5 craftsman
.025 "
Posted on Aug 11, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
SOURCE: I have a Craftsman 650 series lawn mower. It
I have a similar issue in that my Craftsman 650 in that it sputters and smokes out of the muffler and spits oil out from there as well. It does not die, but I cannot operate the lawn mower with all the smoke and oil blowing out. Plus, I get oil leakage on the deck of the lawn mower (top). What would I check for here?
Posted on Mar 28, 2010
Spark Plug Gap for a Sears Mower
Generally .028-.030" if its a small Briggs and Stratton engine.
Aug 09, 2014 | Craftsman 55 Torque 158cc 22" Push Lawn...
My mother in-law has a craftsman 1996 22 inch Lawn Mower, model number 917.377532. Just recently my 18 year old nephew had cleaned the carburetor and replaced the spark plug and primer bulb. It worked for...
how long has it been since it was running good? Todays gas goes bad very fast.
It may not be the Nephews mechanicals skills that is the problem.
Dec 03, 2012 | Garden
Craftsman 6.5,22 inch cut. model# 917.379470
does not sound good the off balance of a loose blade could have caused the rod to break inside the engine the age of mower and how much use it has had could be a factor only way to really know it to look inside the crankcase.
Jun 06, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
I have a Craftsman, 6.75hp, SP, model #917.377580 lawn mower. Was running good but, won't start any more. Don't know if or where the fuel filter would be. Thinking it might be the solid state...
If you know that you have a good plug, and you don't have spark at the plug, then it is a bad Ignition Coil (Module). If you need further help, let me know.
Good Luck!
Jim
Aug 16, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
What is the spark plug for a 6.75 hp craftsman lawn mower
I have the same mower, the gap, according to the product specs. is .030 inches.
Aug 11, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
22 In Craftsman Self propelled.Starts easy, runs good for about 15-20 mins. Starts missing and dies. Will start again in about 30 mins New spark plug/ air filter
Oh my, that is so annoying. There is probably dirt in the carb. or the gas tank. What I think happens is, the dirt gets sucked up into the fuel line and clogs the carb, then when the mower sits for a while the dirt goes back into the tank for another couple minutes. I have absolutely no tolerance for this when it happens.
Aug 05, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Lawnmower runs for 2 or 3 minutes then stops running craftsman 6.5 hp push mower
Sounds like you might have a fuel flow restriction, maybe an in line filter?
Apr 27, 2010 | Craftsman 55 Torque 158cc 22" Push Lawn...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
