Question about U-Line Icemaker
We have a CLR2060. It makes ice fine for several days, then the grid freezes over. We have cleaned it recently.
  • 286 Answers
What did you use to clean the grid? It must be U-line cleaner. I seen people use other cleaners just to find the same results. If the ice isnt ejecting then you can check the hotgas coil. It should be 360 ohms. If its open or week I see this from time to time. If its neither then you need a service tech to repair the sealed system . Replace the hotgas valve.
Posted on May 13, 2009
Will transformer cause icemaker not to cut icee
I have questions for you, does the cutting grid have voltage, is so how much? Check the cutting grid for a broken wire also as a broken wire on the cutting grid will cause the same problem. Good Luck
Aug 22, 2014 | GE Monogram ZDIS15CWW High Production,...
How can i fix my manitowoc qm45a runs water but won't freeze the water?
The thickness sensor is shorting, making the machine continually harvest. Clean it and dry it. If it still happens, replace the sensor.
Aug 05, 2014 | Manitowoc Compact Undercounter Ice Machine...
Have kitchenaid undercounter ice maker, came with the house i bought a year ago. the problem is the water freezes in the resevoir. i have replaced the circulating pump, the thermistor, some sensor,...
on the right side of the ice bin and above the cutter grid are 2 sensor plugs, unplug the one towards the rear of the machine (usually has light brown w/red striped wires). if this does not fix the problem then replace the main control board and the transformer. Also the water doesn't go to the grid, it rolls across the evaporator, freezes a slab of ice that then slides down to the cutter grid. the cutter grid should be somewhat warm, it is what cuts the ice into the little squares. I've worked on these machines for around 7 years now and have only seen this problem once, this should fixya
Mar 02, 2011 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice cubes are hollow, freezing cycle too short. machine is clean, condenser is clean. hOW CAN i INCREASE THE ICE CUBE THICKNESS?
You don't specify a model number, but if it's one of the CLR series (e.g. CLR60, CLR2060, CLR2160) there is a small tan colored adjustable resistor 'dial' on the small circuit board located just beneath the ice bin, behind the front access panel. It should look like a round disk with teeth and has markings on it for -2, -1, 0, 1, 2.... Turn it up to +1 (or if it is already there, up one setting). Stop and restart the ice cycle. Wait 24 hours and see if that's enough or too much, and adjust further based on that. Do NOT adjust more than 1 setting in a day, per the user's manual. (And this information is IN the user's manual, so it's suggested reading.) If you don't have a CLR-series unit, then I don't know.
Jul 10, 2009 | U-Line Icemaker
Uline clr2060 produces little ice
First thing is to remove the water from the trough. Pull out the grey standpipe in the back of water trough. Then see if the grid has a good frost pattern.If the frost pattern is NOT even then you need a service call to check the sealed system. If you do have a frost pattern check to see if the water is splashing over or make sure the drain is in the bin drain hole.If water is getting in the bin then the ice can melt as fast as it makes it.Make sure your cleaning with U-line cleaner.
May 26, 2009 | U-Line Icemaker
Ice Cubes won't drop out
The thickness probe should be approximatly 1/4 inch off of the evaporator.Sounds like you might have loose grids on the evaporator.turn the unit off and remove the curtain.use a flash light and inspect the grids.There should not be space in between the joints,if there is the ice will freeze behind the grids and not properly release when in harvest. Also gently pull at the grids,if they pull towards you or wiggle then they are separating. I have removed one of the grids and had the unit continue to run for sometime until the evaporator could be replaced.The plating being spotty causes release issues as well.Finally check the level of the machine,front to back and side to side.Not being level will also cause release problems
Feb 18, 2009 | Freezers
CLR2060 Clear Ice Maker Won't Freeze
Water is not supposed to run all the time. Maybe you have a problem with your solenoid or the circuit that shuts your water. Sometimes solenoid just needs cleaning.
Aug 08, 2008 | U-Line Icemaker
Clr2060 water freezes but it never dumps the ice.
You might try adjusting the “ice thickness” setting on the control board or you cold have a defective hot gas flow back solenoid. When the machine goes into harvest mode this solenoid activates and allows hot refrigerant gas to flow backwards in the system and melts the ice off the grid and then it falls into the bin.
May 27, 2008 | U-Line Icemaker
Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Nov 06, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
U-Line Icemaker Logo
195 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
