Question about Thermador MBBS Microwave Oven
Is there a replacement microwave for the Thermador MBBS/01
I am looking replacement microwave for my Thermador MBBS/01 and understand all of the issues about dimension of the newer microwaves. My question is what will work in that space and still look acceptable? Thank you in advance
  • Cindi Nov 28, 2012
    I just spoke with Thermador and asked if this model would be compatible and they said it wouldn't work as it is vented differently. What do I do?????
  • Patrick Jan 24, 2013
    cindi, any luck with replacing the microwave? I am having similar problem and need to replace my Thermador MBBS.
  • Thermador Master
  • 9,047 Answers
The MBBS sereis was replaced by the MBES series.
Specs are here.
Posted on Nov 28, 2012
MicrowaveSvc
  • 9047 Answers
SOURCE: Thermador MBBS/01
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
Posted on Nov 28, 2007
SOURCE: TURNTABLE INOP on mbbs/01 thermador microwave
easy...first thought it was a program glitch. turntable could be turned off manually. nope ...just a bad motor needed replacement
Posted on Sep 15, 2009
SOURCE: Need replacement microwave for 6 yr. old Thermador MBBS microwave
I have the Thermador MBBS/01 in a Theramdor oven/warming drawer/microwave unit. When I was told it would be $600 to repair it, I called thermador & they don't make a replacement. Thermador CS was even rude about it. I searched & searched for a microwave that would fit & found a GE model JEB1860M1SS at Home Depot for $259.00. My husband & I just installed it & the frame kit inside, on the old Thermador micorwave fit PERFECT! I could not believe it. I thought we would either have to settle for something looking tacky in the hole or buy a whole new unit. Looks like it came in that unit.
Posted on Mar 27, 2010
heatman101
  • 43501 Answers
SOURCE: thermador built in microwave turns
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Apr 02, 2011
MicrowaveSvc
  • 9047 Answers
SOURCE: I need to replace the
Waveguide "cover"I presume? The waveguide is part of the chassis and cannot be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on May 26, 2011
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
I need to replace the waveguide in my Thermador MBBS / 01 microwave.
May 26, 2011 | Thermador MBBS Microwave Oven
Thermador built in microwave turns on but wont heat worked great this morning. model# MBBS/01 serial# FD8602
heatman101
Apr 02, 2011 | Thermador MBBS Microwave Oven
Mbbs/01 microwave makes noise when turned on and doesn't get hot. Is it fixable or need to be replaced?
Sorry to read about your problem, I hope this helps you out.
yes they are all fixable..just depends on repair cost
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Thermador MBBS Microwave Oven
Is there a replacement microwave for thermador MBBS that fits MT30S trim kit?
Thermador doesn't make one, but we found the GE JEB1860SM1SS from Home Depot fit perfectly. For only $259. The repair to fix our Thermador was $618. It was only 5 years old. I couldn't believe it already went out. I won't be buying anymore Thermador appliances.
Dec 20, 2009 | Thermador MBBS Microwave Oven
Same issue with my Thermador Microwave!
You may want to look into the possibility of a "panasonic" (specifically a "genius" model) microwave unit that should fit there nicely. most of those Thermador 3 component units had the m/w built by panasonic. (though you'll not get them to tell you that)
I'd like to add, I find it unlikely your's is "burned beyond repair". what is the problem, if you'd care to elaborate.
Perhaps your m/w can be saved, or revived.
Sep 25, 2009 | Thermador MBBS Microwave Oven
Sep 16, 2009 | Thermador MBBS Microwave Oven
Sep 14, 2009 | Thermador MBBS Microwave Oven
Microwave appears to work fine but will not heat at all.
Sounds like the thermal protector on the mag tube quit. It may have gotten too hot and opened up. That is the lesser of all the evils that can happen to a Microwave.
Feb 04, 2008 | Thermador MBBS Microwave Oven
Thermador MBBS Microwave Oven Logo
622 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
