Question about SewShop.com Singer Model 6510 Scholastic Instruction Manual
I can't get my any of my stretch stitches to work on my Singer 3 dial model 6510.
I set the stitch length dial to "S" and the Pattern selector to "G" on the Stretch side and all I get is the pattern for "G" on the Utility side.
  • Sharon Robson Nov 28, 2012
    I have the manual and follow it exactly. Doesn't work. Thanks to small6363 for trying to help anyway.
  • SewShop.com Master
  • 18,392 Answers
How do you adjust the stitch length
Did you get your answer yet? There are dials on your machine...the one on the lower right near the bottom of the machine is the length dial. You need to get yourself a manual if you don't have one. You can email me if you want more info, good luck!
Aug 30, 2014 | SewShop.com Singer Model 920 Futura II...
Machine is stuck on reverse mode
Try this,Go back to straight stitch, zero your stitch length,zero your stitch width, turn your hand wheel towards you for few rounds then select a stitch length and see if the reverse lever will work normal after this. Otherwise get it fix by a local technician.
Nov 08, 2013 | Singer 4423 Electric Sewing Machine
The reverse won't work on my singer 9018 sewing machine
STITCHING IN REVERSE
• To reinforce beginnings or ends of seams, push in
reverse lever
(1). Machine will straight stitch in
reverse for as long as you hold the lever in.
• For continuous reverse stitching, push lever in and
slide it to the left to lock. Unlock reverse lever by sliding
it back to the right and letting it return to its normal
position. if you need a manual let me know,,
Nov 25, 2012 | SewShop.com Singer Model 9018 Instruction...
Singer Stylist 7258 will only sew backwards and is only making holes...no stitches!
this link is for the manual go to page 32 ,it sounds like you have it on button hole stitch witch goes in revers, you need to press button hole off switch.
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Oct 23, 2012 | Singer Stylist 7258 Electric Sewing...
I own a singer 14sh654. Bottom stitch really loose,don't know what to set any of the dials at to make it work right. The top stitch is neat tight bottom all over the place
Hi. Loose stitching underneath means you need to increase the upper tension. Try just a little at a time, using scrap fabric of similar weight to what you want to sew.
Aug 19, 2011 | Singer Vacuums
I'm new to sewing. It did not come with an operating guide and I find the stitch settings really confusing I would like to know how to set it to do a basic straight stitch for a simple dress pattern....
Look for the row of straight vertical lines. This is the straight stitch. There will also be a number dial for stitch length. Use a piece of scrap to find the length of stitch you want. Make sure you have the bottom feed lever or button activated. This will operate the textured plates that come up from underneath to move the material forward or reverse. Also, make sure you drop the presser foot lever before you start. Hold both threads, manually lower the needle to the first stitch starting point and use the pedal from there on. When you press the pedal, you can let go of the threads.
May 14, 2011 | Vacuums
SewShop.com Singer Model 6510 Scholastic Instruction Manual Logo
150 people viewed this question
Top SewShop.com Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
