Question about Maytag MSD2434GE Side by Side Refrigerator
Maytag Refrigerator, Vibrating Noise
Vibrating noise coming from the freezer area. I check the fan blade, cleaned the tray underneath the compressor and emptied the freezer. Noise still continues. Only lasts for a short time, but sounds like a rattling. I am a pretty sure the compressor is fine because when I pulled the refrigerator away from the wall I couldn't hear anything. And the refrigerator andw freezer continue to work great. *Note: Refrigerator on top of freezer, double doors for refrigerator and freezer sliding door
    Problem Solver:
  • 16 Answers
What is a short time? 5 or 6 secondswould be icemaker fill valve.Tubing in back is a common noise maker ,could be somthing hitting the condenser fan blade.
Posted on Nov 28, 2012
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Frig. and Freezer not cooling. Clicking sounds heard every 2 mins
sure sounds as if it is def a compressor overheating, now that the compressoe will be cooled it should work , but your right damage may be already done, the good news if any is that you should be covered under 5yr manufactures warr for compressor
Posted on Dec 22, 2008
  • 16 Answers
SOURCE: Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Posted on Jun 02, 2009
  • 24 Answers
SOURCE: Refrigerator doesn't cool/freeze - clicking, cyclying noise repeates, but doesn't cool
I've been told by a tech who repaired my MFD2560HEQ this past week that many of this model had a problem with compressor failure. Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. Maytag, I believe, has a five year warranty on the compressors. They did on mine, but unless you have an extended warranty the labor replacing it is not covered and that will be around 2-3 hours worth. This is the price we are paying for our quest for energy efficiency. Compressors are being built so small and light that they fail much more often than grandma's old, old refrigerator that was built like Fort Knox and ran for 45 years, remember? But we're being energy efficient! Thank you environmental extremists! I wish I could send you the repair bill.
Posted on Nov 08, 2009
  • 230 Answers
SOURCE: My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Posted on Sep 08, 2012
My fridge is making a lot of noise. It does not stop. What might the problem be? Model# 2539668010 Serial# BA62202425
This is a basic no frills refrigerator so that things that can make a lot of noise is limited. And where you say it doesn't stop, then it is most likely a fan. You have two one in the freezer compartment that could have accumulated some ice on the blades which could through it out of alignment. So it might be hitting the sides of the case.
The other fan is underneath your cabinet, and blows air across the compressor, and condenser coil. If there is a lot of lint or debie in this area then the fan blades could be come coated and then the out of balance condition could cause noise.
If a cleaning doesn't fix the problem then you will probably have to replace the fan blades and motor.
Jul 05, 2011 | Kenmore Top Freezer Refrigerator
Refrigerator makes a loud knocking sound at random. May go for days without making the noise, then will make noise randomly throughout the day for several days in a row. Freezing compartment, frig, water...
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.
Aug 24, 2010 | Kenmore 74252 / 74254 / 74259 Top Freezer...
Loud fan noise
Jun 02, 2010 | Whirlpool ED2FHEXN Side by Side...
Loud humming noise
May 23, 2010 | Amana ABB1927DE Bottom Freezer...
Hotpoint refrigerator CTX 18G makes noise when compressor comes on. I opened the the back bottom panel and the noise went away when I unpluged the plug on the far left (as viewed from the back) was...
No. This is not affecting the operational value of the compressor at all. It is just an annoyance, at most. I would recommend to inspect the entire unit for other noise enablers, as well.Here are a few areas that will cause abnormal noises in your unit.
Dec 29, 2009 | Hotpoint Refrigerators
Hollow, glass on glass knocking noise when compressor is shutting down, lasts almost 2 minutes.Tried tightening the metal case, cleaned coils, all areas under fridge. What next?
Dec 15, 2009 | Frigidaire Refrigerators
Loud vibration sound coming from rear bottom near motor? sounds like my porter cable compressor running.
Dec 14, 2009 | Washing Machines
GE refrigerator runs extremely loud. Sounds like it may be coming from the ice maker or freezer area.
Dec 03, 2009 | GE Refrigerators
Makes a loud squaling noise. Noise comes and goes. Sounds like it is coming from the bottom and back of the fridge. I have no idea what it could be? Any ideas? Thanks
Nov 28, 2009 | LG LSC26905TT Side by Side Refrigerator
Why is there a loud knocking noise when my refrigerator shuts off? The volume of the noise differs each time that the unit shuts off
Nov 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
Maytag MSD2434GE Side by Side Refrigerator Logo
352 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
