Question about RCA 46 46LA45RQ LCD TV
My rca 46 lcd has different color lines on the screen, what can i do?
  • RCA Master
  • 933 Answers
Get a diagnoses done on the set. It is possible you could have one of the following problems;
bad LCD panel
bad t-con board
bad ribbon cable connection
Posted on Nov 28, 2012
5 Suggested Answers
gfxmaxx
  • 155 Answers
SOURCE: My RCA lcd 1080P flat
Test on something else like laptop or friends pc to eliminate the monitor or pcs video card.
Posted on May 06, 2011
ThaMp3Doctor
  • 8596 Answers
SOURCE: rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Posted on Jan 03, 2009
jerryg50
  • 1667 Answers
SOURCE: rca 46" lcd hdtv picture artifacts.
The matrix drive board, or the screen itself most likely has failures. The fix is to change the board, or to replace the screen assembly.
On rare occasions it may be a bad connection with one of the ribbon cable assemblies that is not too complicated to service.
This type of repair may not be feasible. You will have to have an estimate done.
Jerry G.
Posted on Feb 10, 2009
  • 8457 Answers
SOURCE: Need to order a replacement 46" LCD Screen
Sorry,not repairable,because the LCD screen panels are limited produce by the Tvs Corporations.No where u will able to buy a LCD Screen panel for the replament,but except by the tvs corporations themselves.Because it limited production of the LCD screen panels,they will sell it to u the same as a new tv.Might even cost more after the labors of by replacing the LCD screen panel.
Posted on May 23, 2010
RCA LED LCD TV Vertical Line Problem
Sounds like your display driver board is broken. Try claiming warranty.
Jul 02, 2016 | RCA LED55C55R120Q 55" LED TV 1920x1080,...
COLORED VERTICAL LINE ON THE ENTIRE SCREEN AND NO PICTURE Sony Bravia KDL-46VL160 46 in. LCD HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 03, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
My RCA 46 LCD has no picture or sound but the blue lights on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 02, 2015 | RCA Televison & Video
My RCA 42 inch TV turns on but I see nothing but different color lines on the screen and no sound.
Lines on the screen usually is a problem with LVDS board, panel or the ribbon cable to the panel. Set should have audio though. the main board processes both audio and video but will not produce colored lines.
Feb 03, 2015 | RCA L42WD250 42 in. LCD HDTV
Hi, I'm having trouble with a samsung 46" led tv. A few seconds after being turned on, colored vertical lines appear in front of whatever show is on. These lines will appear in different areas at...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Screen-shots to defective LCD are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent. Line faults to LCD TVs too are given with illustrations.
Jul 22, 2014 | Televison & Video
LN46B610A5FXZA Gray Horizontal across full Screen with color vertical lines in lt corner and center of screen
Sounds like a panel defect. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 26, 2012 | Samsung LN46B650 46/49.5 in. LCD HDTV
46LA45RQ
The T'Con board to your TV is faulty. If you have some knowledge in electronics, you can replace it. Instructions to replace it can be seen the site named Electro-help. Check this link and select it.
Jul 04, 2012 | RCA 46 46LA45RQ LCD TV
Rca 46" lcd hdtv picture artifacts.
Jerry G.
Feb 10, 2009 | RCA L46WD250 46 in. LCD HDTV
Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
RCA 46 46LA45RQ LCD TV Logo
427 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
