Question about American Standard 2083.102 Standard Collection Bathtub, Right hand outlet
New 352658 shower faucet drips
I just installed this American Standard faucet and took the shutoff valve apart to check for debri and found none. It still drips. Any sugestions?
    New Friend:
  • 51 Answers
They are bad about leaking,you prob. need to replace the cartridge with new one. the seals in them get dry and shrink of they have been sitting in the box for a long time on the shelf or in a warehouse. you never know how long ago they were built and just sitting.
Posted on Dec 18, 2012
2 Suggested Answers
  • 10865 Answers
SOURCE: NEW American Standard shower installed... leaks from shower head.
They do not all leak. The problem may be that your faucet is simply wearing out and is due to be replaced in total. Try putting some plumbers grease on the cartridge and the chamber.....not too much..........that may do the trick for u.
Posted on May 19, 2009
American standard single handle shower vavle drips when tub spout is on.
Be sure to pull the plunger all the way up when diverting the water between the the tub and shower if ti keeps giving you a problem it's faulty
Mar 05, 2016 | American Standard Home
We have no hot water coming out of our bathtub faucet. We took it all apart and water is only coming our of the cold side of the pipe
there is probably a shutoff on the rough-in valve in the wall. Sometimes the seal in that comes apart and blocks the water. Get new stem for valve. Unscrew the nut, replace stem, tighten nut. Clean inside valve before u put new one in.
Oct 10, 2015 | Delta & Single Handle Shower Faucet
No water flow from new american standard marquette showerhead
I think fitting of your shower is not proper. You have to fit it properly if you can or you can call a nearest Plumber to solve your problem.
Mar 13, 2014 | American Standard Home
The shower does not get hot so i took pressure balance unit apart and cleaned also took hot limit stop off .still not hot rest of sinks in house are hot and furnace right under shower,what do you think it...
When shower faucet apart make sure hot is getting 2 & coming out faucet ***. did you turn off stop integral w/ faucet or outgoing shut off valve on water heater.. May have rust or lime in small orifice leading to faucet ***. does your balancer/ piston move freely..good luck..
Mar 24, 2011 | American Standard Bath Faucet Ceramix...
I just installed an American Standard easy touch faucet 6310F. The pressure is very low. Anybody know what the problem may be?
At the base of the handle there is a flow regulating check valve. Shut off water supply and unscrew handle and look for debris. Many times the washers break down on the shutoffs under the sink and release "crumbs", these usually block aerators and sometimes the cartridges on certain faucets. Hope this was helpful.
Feb 16, 2011 | American Standard Kitchen Faucet 6310 020...
Water will not flow through on american standard with pressure balance. Some hot water came out with low pressure then stopped and now nothing will flow.
I just spent a week wrestling with a similar problem, and I'm posting in an attempt to save someone else an ulcer. Using a Colony single-handle valve, the temperature got so we couldn't control it. Either all hot or all cold. I called A.S. and they sent a new pressure balancing cartridge and new valve cartridge. Replaced both and then there was no water at all coming out of the shower head. Tried every possible combination of old and new parts, flushed pipes, etc. Finally took the shower head off and found it completely clogged with debris. It was a mix of sediment and the white grease that was in the new cartridges, which must have been displaced when I started messing with it. And it clogged it all at once (no flow problems before all of this). Works fine now!
Jan 02, 2011 | American Standard One Handle Shower Only...
I have an American Standard shower that drips out the shower head. When other faucets are used in the bathroom the water pours. I replaced the cartridge put it still drips.What could be the problem?
Hi kwbaker!
Assuming the cartridge is new and the water drips at both hot and cold settings, I would check your shower head. It is not uncommon for debris to collect in the screening there and clog the spray nozzle.
To check the shower head you'll need to remove it from its piping. Use two tools--I normally use an adjustable wrench and a strap wrench--to hold the wall pipe and simultaneaously turn the shower head counter-clockwise. The cresecent wrench grabs the hex-head of the shower head, while the strap wrench holds the chromed piping without scratching it.
Be sure you don't lose the rubber washer inside the pipe-to-shower head connection!
Once the head is removed, look inside it at the pipe side. You should be able to see into the mechanicals of the shower head--very often I'll see bits of rust or scale. Oftentimes its enough to rinse the pipe side of the head under a sink; in extreme situations it can be easier to replace the entire shower head.
To replace the shower head, use two tools in the same manner in which the head was removed: crescent wrench to turn the shower head, strap wrench to hold supply piping. This time, however, turn the shower head clockwise until it tightens snug.
Hope this helps!
--Joe
Nov 12, 2010 | American Standard One Handle Shower Only...
Constant drip
there may be some debris caught in the cartridge's,got push'ed in when water was turned back on.take apart and look in the brass valve body to see if any thing is in there.flush it out before you re-assemble it.take a good look at the cartridge,make sure there is no scuff mark's or any deformities.
Apr 26, 2010 | Moen & One Handle Tub & Shower Faucet
Leaking shower faucet
You may want to disassymble the faucet again and check for any debris that could have gotten into the faucet when you were changing the cartridge. Also remove the seats at the back of the housing and reexamine for bad seals. Sometimes it takes a second install for it to stop. Something isn't seating properly plus, it could be a bad new cartridge.
Apr 07, 2009 | Plumbing
American Standard Cadet 2-handle tub & shower set-Model#3275 - low pressure output
When you installed the new tub faucet you probably turned off the water to that faucet of even the whole house. IF IT IS AN OLDER HOUSE, TURNING THE WATER OFF AND BACK ON CAN LOOSEN SOME DEBRIS IN THE WATER LINES THAT CAN FIND THEIR WAY TO YOUR NEW FAUCET. If there is a screen at the end of the water outlet it can be clogged with gunk. Uncrew the screen on the water outlet and clean. You may also want to flush out the hot and cold outlets by turning the water off, removing the cartigages and slowly let water flush them out. Then reassemble. Also when you have the tub handles out you can turn the hot and cold supply valves off and on a few times to loosen more debris if it exsists........Joe
Oct 24, 2008 | American Standard Colony 3275.505 099...
American Standard 2083.102 Standard Collection Bathtub, Right hand outlet Logo
153 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
