Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
Belkin hub causing computer to contantly restart
I added a belkin network usb hub to allow whole house to print etc through wireless connection. It installed correctly and found the connected printer and external drive. It is constantly connected and turn on but when the computer is initially turned on it fires up as normal opens to the desktop, the belkin network page comes on automatically showing the printer and external drive are connected then the computer automatically restarts itself before i can do anything and continues to repeat the above process. If I unplug the hub it works as normal. any ideas how I can solve this would be appreciated.
  • Anonymous Apr 26, 2009
    I am using a Belkin N1 Wireless adapter and it's causing my computer to resart also.
    Genius:
  • 1,913 Answers
Connect with other usb port
Posted on Jan 10, 2009
SOURCE:
Installed belkin Surf USB but it is unable to get Ip address from bt hub tried uninstalling and reinstalling no change
there is a button on the bt hub with the wireless sign on it, press it to allow the usb device to connect. You onlt need to to do this once its a security measure to stop anyone logging into your wireless network. Also it will only stay allowable for connections for a short period of time. But as i have said you only need to do it once to allow the new computer to connect.
Please vote if you found this info useful
Mar 15, 2011 | Belkin Surf Share Wireless USB Adapters...
We have a Belkin USB hub successfully networking 3 printers to two PCs. We are currently making the drastic switch to two new iMacs to replace the decrepit, outdated PCs. How can we get the printers up...
it's a wireless access point;configure your imacs pc with any pivate ip address like 192.168.1.1/192.168.1.2 etc and don't forget to installed ethernet driver and wireless daemon is on select the authenication protocols as stated in the access point;hope it connect
Dec 01, 2009 | Belkin 5-Port USB Hub
Belkin Wireless 5-Port Hub (F5L009) Problem
If you set the allowed IP address in the security section of the router then you must fix your computer IP to 192.168.1.101 with a subnet mask of 255.255.255.0 the default gateway should still be 192.168.1.1 and when you get in delete the security locking out all but the one address. Good Luck
Sep 03, 2009 | Belkin Wireless USB Hub
HP printer will not print over wireless network using Belkin hub
Try turning everything off, wait a couple of seconds and then turn it back on.  Also try disabling McAffee to test.  When you go to printers and faxes on the PC, what is the status of your printer?
Apr 16, 2009 | Belkin (F5U237) 7-Port USB Hub
WD My Book 1TB not recognised by belkin modem router USB storage
I have a work around for this.
In the detail of the Belkin manuals it says you can attach up to 4 USB storage devices via a USB HUB.
I had an old Hub so I Connected the HUB to the router and the Maxtor to the HUB --- It worked :-) It came up in a few seconds.
At first I powered the HUB but later took the power out of the hub and it still worked ;-} However when I used a different HUB it would not work without power to the HUB.
The HUB I use is an old Belkin 4 port Tetra Hub. The newer 7 port Belkin HUB (5 Rear 2 Top) only worked with the HUB powered.
Hope this helps untill Belkin Upgrade the Router sofrtare.
Apr 07, 2009 | Computers & Internet
Can I wirelessly network my HP Officejet J5780 printer?
What you are saying will not work . The J5780 only connects with a USB. It does not have a J45 connection. So to play with the "built in network server" would do nothing. You would have to have some way to convert the USB to a J45 so he could hook it to his Wireless Router. His only alternative is to hook it to another computer that is used as a Wireless Slave that is shared or to get a print server. Hower, Belkin does make a wireless USB Hub that converts 5 USB's to J45 and can be hooked to you Wireless Router. It also has a built in Print Server. You can take this device and instead of hooking it J45 to the Router you can hook it to a linksys Bridge and now the USB HUB from Belkin becomes completely wireless. And has a Print server to boot! The model number are Belkin "Network USB Hub" and the Linksys WET54G.
Since the Hub connects to the USB devices and then converts them to a J45, to link to a network you can hook it to the llinksys device and convert it to a wireless network usb hub. It also has a print server built in.
It works. I own the same printer all in one and if you search on the internet you can pick up both devices on the cheap.
Jan 05, 2009 | HP Officejet J5780 All-In-One InkJet...
Blue screen with multifunctional printers
Normally the USB hub is design to connect to the device that doesn't consume electricity like handy drive,MP3 player.So in your case the multifunctional printer, I think this one really need a direct connection to your PC,instead of going through USB hub.Try to move some other device to connect to this hub and connect your printer directly to PC..due to many restriction with printer like electricity,port,etc...
Apr 17, 2008 | Belkin Wireless USB Hub
Connecting to secure network
when enabling wireless security the router and adapter must be both be configured and configured in a fashion that both support. If you need help provide confirmation of your wireless router's manufacturer and model and the same information for any wireless adapters or computers with built-in wireless adapters to be wirelessly connected.
This will allow us to determine the common security options for all wireless devices you have.
Dec 16, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
90 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
