Question about Kenmore Elite HE5t Washer
Instruction of how to change bellow of kenmore elite he5t front load washer
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
See if this video helps you. It is for an HE3 but should be about the same process.
Posted on Nov 27, 2012
  • 3 Answers
SOURCE: Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Posted on Dec 29, 2007
jsrock516
  • 5911 Answers
SOURCE: How Do I replace the
Here ya go, click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the instructions thoroughly before starting. This is a fairly straight forward and simple repair job. If you require further assistance, go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
Posted on Jun 16, 2008
  • 3 Answers
SOURCE: Kenmore Elite He5t front load waher
hey there is a temo fix till some body comes to your home if you remove the soap try and reach in to the back of the opening you can rest the spring loaded wheel that controls the soap disspenser and that will stop the clicking and allow the machine to run!!!!! after reading all the post i could find i figured it out now my washer is running fine!!!
Posted on Aug 09, 2008
blueextc3221
  • 15935 Answers
SOURCE: Keeps flashing F35, when unplugged and plugged
F35 Is an electrical fault in the Control Board.
Try setting the machine on off.
Then remove the plug from the wall for 5minutes. this will usually reset the system and get you going if it is only a glitch in the electrical system.
If this fails to remedy the problem then you have what appears to be a failed control board.
The only way to be sure is to have it diagnosed by a hands on tech.
Or risk your money by swapping it out your self.
The problem is that usually when my customers try this, they end up spending part money and then a service call on top of their failed attempt.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Posted on Mar 16, 2009
mgprice
  • 744 Answers
SOURCE: He5t Kenmore ELITE front load washer flashing f35 code
Hi, Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch. If you have any further questions or concerns please feel free to comment again, Good luck.
Posted on Jul 07, 2009
Where is the presure switch locate at on a Kenmore Elite HE5t. Is there a diagram of it?
Take off the lid of the washer. In the back right of the washer it has a small hose attached to it
Aug 24, 2012 | Kenmore Elite 45986 Front Load Washer
Is it easy to change the rubber seal on Kenmore He5t washer?
Hello, Thank You for using FixYa. I will be helping you today.Its not bad. When you open the door there is a wire with a spring holding on the outside part of the bellow grab with needle nose pliers and pull and when off push the bellow into the washer on this model i believe on the left side put your hand in there is a big hose clamp holding the inside to the tub there is a screw you will feel loosen it and pull the whole bellow off.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Kenmore Elite HE5t Washer
We have a kenmore elite he5t front load washer, that i just finished replacing the bellow on. after reassembling the front panels, i tried to start the washer to run a cleaning cycle, but all that happens...
Thats usually a sign that the door is still open. Make sure that when you put the bellows on the ring that goes around it was put on properly as well that way the door is actually fully closing engaging the door swithch and letting the machine know its ok to run.
Nov 07, 2010 | Kenmore Elite HE5t Washer
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Bellow for Kenmore Elite front-loader washer
The Bellow should be available at a appliance part store. be sure to call with the model number and serial number, that way if they don't have it they will have time to order it.
Apr 12, 2010 | Kenmore Elite 45986 Front Load Washer
F20 message on washer kenmore elite HE5t
Feb 28, 2010 | Kenmore Elite HE5t Washer
Kenmore elite washer he5t error codr f21
remove bottom panel 3 screws 7mm get bucket and alot towels, turn pump filter clockwise and remove all debris from inside pump now close it up nice and tight should solve youre problem
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Bellow Replacement
Make sure the drain holes are clear in the bottom of the bellow. Also, make sure the bellow is aligned properly. There should have been an alignment arrow at the 12 o'clock position. Hope this helps.
Aug 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
447 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
